Programming a clock that counts down
Discussion in 'Programmer's Corner' started by SofiaEdqvist, May 9, 2012.
  1. SofiaEdqvist
    May 9, 2012
    Hello! I need help to program a clock that counts down from two minutes to zero. I've done a code in Keil, it should be so here 2:00 with three 7-segment displays. Here is the code that I have done:
    START EQU P3.1
    RESET EQU P3.0
    DISA EQU P3.3
    DISB EQU P3.2
    DISC EQU P3.6
    ORG 0000H
    LJMP MAIN
    ORG 0060H
    MAIN:
    JB START,$ ;WAIT FOR START BUTTON TO BE PRESSED
    SETB DISA
    SETB DISB
    SETB DISC
    DD1:SETB DISA
    MOV A,#02H ;SETTING FOR MINUTE
    MOV R1,A
    DS1:MOV P0,R1
    DD2:MOV A,#00H
    MOV A,#05H
    DS2:MOV P2,A
    DD3:MOV A,#00H
    MOV P0,R1
    MOV A,#09H
    DS3:MOV P1,A
    LCALL DELAY
    DEC A
    CJNE A,#00H,DS3
    MOV A,P2
    MOV P1,#00H
    ACALL DELAY
    DEC A
    CJNE A,#00H,DS2
    TEN:MOV P2,#00H
    MOV R6,#09H
    TE:MOV P1,R6
    DEC R6
    ACALL DELAY
    CJNE R6,#00H,TE
    MOV P1,#00H
    DEC R1
    ACALL DELAY
    MOV P0,R1
    CJNE R1,#00H,DS1
    MOV P0,#00H
    LASTMIN:
    DE2:MOV A,#05H
    DF2:MOV P2,A
    DE3:MOV A,#09H
    DF3:MOV P1,A
    LCALL DELAY
    DEC A
    CJNE A,#00H,DF3
    MOV A,P2
    MOV P1,#00H
    ACALL DELAY
    DEC A
    CJNE A,#00H,DF2
    LASTEN:
    MOV P0,#00H
    MOV P2,#00H
    MOV R6,#09H
    TE1:MOV P1,R6
    DEC R6
    ACALL DELAY
    CJNE R6,#00H,TE1
    MOV P1,#00H
    RST: ;CLEARS ALL DISPLAYS AND RETURNS TO START
    JB RESET,$
    CLR DISA
    CLR DISB
    CLR DISC
    JMP MAIN
    DELAY: ;DELAY OF ONE SECOND
    MOV TMOD,#01H
    MOV TH0,#3CH
    MOV TL0,#0B0H
    MOV R7,#00H
    SETB TR0
    DEL:JNB TF0,DEL
    MOV TH0,#3CH
    MOV TL0,#0B0H
    CLR TF0
    INC R7
    CJNE R7,#14H,DEL
    RET
    END
    I'm really grateful if anyone can help me, I've been doing this for several hours, days and nothing works.
  2. #12
    Nov 30, 2010
    16,704
    7,352
    You might want to post this in "Programmers Corner" on this site.
    I'll tell the boss and see if he wants to move this.
