Programmable thermometer to 110 relay for a complete newbie
Discussion in 'The Projects Forum' started by Awodzenski, Oct 30, 2013.
  1. Awodzenski
    Oct 30, 2013
    I have no experience when it comes to microcontrollers and have always wanted to get into them and I thought this project might be perfect.
    I am making a fish breading tank and the water needs to be chilled to different temperatures depending on where they are in the cycle.
    I have the cooling system set up I just need a way to turn a 110v water pump on and off at a specific temperature. I thought the best way to do this was with a microcontroller.
    I would like a set up so I could start to make other things with microcontrollers as time goes on.
    I am not sure where to go to get started and was hoping to get some help from people who know what they’re doing.
    Any input about any of this would be great!
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Last time I needed a temperature controller for a liquid bath I bought one of these... Works great. It is "programable" as to temperature and hysteresis...
    wayneh likes this.
  3. mcgyvr
    Oct 15, 2009
    4,793
    976
    ^^ yep thats the "easiest" ... no need for a micro/programming at all..
    Or an easy micro route would be with an arduino/waterproof lm35/relay shield.
  4. wayneh
    Sep 9, 2010
    12,405
    3,255
    You don't need a micro to build a thermostat, unless you want fancy options like a readout and all that. I use LM35 - comparator - MOSFET or in this case add a relay. Tough to beat a $20, purpose-built device though.
  5. mcgyvr
    Oct 15, 2009
    4,793
    976
    I only said micro as the OP wanted some "micro experience"..
  6. #12
    Nov 30, 2010
    16,705
    7,358
    Agreed. $20 is a no-brainer solution, but the OP wants experience in MCU's.
    Good enough to start with something this simple.
