Programmable Relay Controller for Solenoid Valves
Discussion in 'The Projects Forum' started by aberrant, Jan 6, 2011.
  1. aberrant
    Jan 6, 2011
    I'm looking for a programmable relay controller such as this one Needs to be SPDT, but I need one that I can power 16 solenoid valves off of. I'm not sure if anyone would know if they make programmable relay controllers specifically for solenoid valves. I know solenoids give a kickback emf so if I have to I can wire in a separate board with a diode and a fuse in between each relay and its solenoid, right? It's just easier if I could keep everything on one board. Any ideas?
    Here's the solenoid I'm using:
    Thanks in advance for the help
  2. blueroomelectronics
    Jul 22, 2007
    Those relays should be fine. You might need snubbers across the contacts.
