As you know, the Z80PIO was make by the same company as the Z80, so it was designed to work together. You will need to check the timing diagrams to see if the address and data lines are properly provided to address and send/retrieve data from the Z80PIO using the 8051 MCU. I believe that the lower address lines and the data lines are multiplexed.Can the Z80PIO be interfaced with an 8051 micro-controller? or is it specified to be used only with the Z80 CPU?
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Jake Hertz
