Programmable off the shelf resistor
Discussion in 'The Projects Forum' started by jismagic, Feb 12, 2016.
  1. jismagic
    Sep 7, 2013
    77
    I have 5-6 Analog inputs, with voltage input to it is controlled by resistance values in the range (0-200K, resolution 10ohms).
    Looking for programming /setitng resistance values over PC.
    Any ideas !
    (Not looking for- Analog out or voltage input due to other limitation)
    thanks
    jis
  2. hp1729
    Nov 23, 2015
    2,105
    235
    Something like a digital pot? 10 ohm resolution might be hard to get. Maybe a digital pot at the output of a digital pot? I2C interface or simple 3-wire (Enable, up, down) are popular.
    (edited to add ...)
    Usually the pots work in 256 step increments, so a 200K pot steps in increments of about 780 ohms. If you put a 1K pot in series with that you get a resolution of about 4 ohms. Gross and fine adjustments.
  3. mcgyvr
    Oct 15, 2009
    4,793
    976
    yep.. digital potentiometer
  4. marcf
    Member
    Dec 29, 2014
    149
    20
    If you need digital control of analog input voltages, why not use a I2C DAC?
