programmable IC
Discussion in 'General Electronics Chat' started by pradeeba, Oct 30, 2008.
  1. pradeeba
    Thread Starter Active Member
    Feb 27, 2008
    104
    What is meant by a programmble PWM controller IC?
    Is it programmable means writing code or by connecting external resistor to the particular pin to achieve?
  2. scubasteve_911
    Dec 27, 2007
    1,202
    Why not give us the link to the datasheet ?
    Programmable means a lot of things, typically the setting of registers internal to the IC or using passives externally to alter its functionality.
    Steve
  3. pradeeba
    Feb 27, 2008
    104
    LM5021 is the IC
  4. scubasteve_911
    Dec 27, 2007
    1,202
    "Single Resistor Programmable Oscillator" from the datasheet should be pretty clear.
    You may control the frequency of operation via a single resistor connected to the IC.
    Steve
  5. pradeeba
    Feb 27, 2008
    104
    what are all the criteria to choose a PWM Controller IC?
  6. scubasteve_911
    Dec 27, 2007
    1,202
    Your questions are too general, you need to 'brush up' on what you are doing and, if you get stuck, then ask for help. And consider thanking people for their valuable time.
    Steve
