programmable gate array
Discussion in 'General Electronics Chat' started by PG1995, Oct 5, 2011.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi
    I didn't know there existed programmable gate array. If I have a programmable chip, then can I configure it to behave, say, like the 74LS00 IC? What device is used to program the gate array? Is there something like USB SD card reader? Please help me with this query. Thanks.
  2. kubeek
    Sep 20, 2005
    4,691
    806
    Well, yes you can create a quadruple nand gate, but definitely not in the same package and with the same pinout.
    FPGAs I know need some form of external memory, because the chip remembers nothing and needs to be programmed each time you power it up.
    On the contrary, CPLDs do remember their programming. Read here and here.
    #12 and PG1995 like this.
  3. PG1995
    Apr 15, 2011
    753
    5
    Thank you, Kubeek.
    How do you program them? Using some USB card reader type device?
  4. kubeek
    Sep 20, 2005
    4,691
    806
    Like microcontrollers, each brand will have its own programming cable. Xilinx uses JTAG protocol, not sure about altera but I bet they will use something different.
  5. colinb
    Jun 15, 2011
    351
    35
    CPLDs are programmed by proprietary devices. For instance, Altera CPLDs (such as the low cost MAX II CPLD) can be programmed by their ByteBlaster interfaces (other Altera devices).
  6. PG1995
    Apr 15, 2011
    753
    5
    Thank you, Kubeek, Colin.
    Now I wonder why would someone buy regular IC such as 74LS00 instead of a programmable chip which can be configured to emulate behaviour of different logic chips? To me, programmable one is a many-in-one device and even if it costs slightly higher even then it's worth it. Thanks.
  7. crutschow
    Mar 14, 2008
    13,523
    3,391
    Programmable chips are often used to implement large, complex logic functions. They wouldn't be use to replace simple logic chips like the 74LS00 since they are significantly physically larger, need to be programmed, and cost much more than the simple chips.
    PG1995 likes this.
