Programmable frequency divider chip
Discussion in 'General Electronics Chat' started by taydin, Jan 10, 2014.
  1. taydin
    Dec 10, 2013
    I am trying to find a programmable frequency divider chip, but haven't had any luck so far.
    This chip should have two inputs, where I will connect 22.5792 MHz and 24.576 MHz crystal oscillators. This chip should also have 4 outputs where the divided forms of the input clocks will be present. For example:
    O1 = 22.5792 / 8
    O2 = 24.576 / 4
    O3 = 24.576 / 2
    O4 = 24.576 / 8
    There should also be some kind of a control port (SPI or I2C) that I can use to configure the outputs. It is very important that I use crystal oscillators, so a PLL type synthesizes is a no go.
    I know that this type of circuit is available as ASIC IP's, but I obviously need an IC that does this. Anybody know a chip that does this?
  2. crutschow
    Mar 14, 2008
    13,488
    3,372
    The divider could be a counter such as the 74194. Controlling this from a serial control port will require some type of serial decoder circuit. Not familiar with whats available for that.
  3. #12
    Nov 30, 2010
    16,676
    7,321
    It's called a modulo N divider. I worked on those in 1979 but I forgot the part number. At least I remembered a term to search for it.
  4. taydin
    Dec 10, 2013
    I was hoping to find a chip that has all the dividers, the muxes and the control circuit in it. I can't use discrete logic, that would take too much space. Guess I have to look into getting this done with an FPGA.
