programmable delay circuit
Discussion in 'General Electronics Chat' started by nozfet, Feb 2, 2010.
  1. nozfet
    Feb 2, 2010
    Can anybody help me create a programmable delay circuit. I have a pulse signal that needs to be delayed then fed back into my logic circuit. The delay tolerance is between 1us to 10us.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Post your existing circuit, and indicate where you need the delay to be added.
  3. nozfet
    Feb 2, 2010
    the circuit is pretty simple and I know how to create a delay using the 555 timer, however I was looking to create the delay using a more elaborate circuit with a counter and user adjustable. The circuit has a sipex transceiver chip at the input of the delay circuit then comes the delay and then fed back into another sipex transceiver.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, so run the signal through an octal shift register that's being clocked at a MHz or so. Use a rotary switch or octal DIP switch to select which output your signal comes from.
  5. jans123
    Jan 30, 2010
    20
    If I was into programming I would go for a PIC processor. The 8-pin devices are dirt cheap and quite potent. A delay would mean only a few lines of code. I have seen it done, but never used it myselves.
