Programm on MKICROC
Discussion in 'The Projects Forum' started by splendid-electron, Feb 24, 2014.
  1. splendid-electron
    Jan 26, 2014
    14
    I'm trying to understand how this programm work can you help me
    it's about a tchometer contact less it count the speed with PIC18F2550
    Code ( (Unknown Language)):
    1.
    2.  sbit IR_Tx at RA3_bit;
    3. // Define Messages
    4.  char message1[] = "2014TACHY.V3.COM";
    5.  char *RPM = "00000 RPM";
    6. //================================================
    7.  void Display_RPM(unsigned long num)
    8.    {
    9.       RPM[0] = num/10000 + 48;
    10.       RPM[1] = (num/1000)%10 + 48;
    11.       RPM[2] = (num/100)%10 + 48;
    12.       RPM[3] = (num/10)%10 + 48;
    13.       RPM[4] = num%10 + 48;
    14.       Lcd_Out(2,4,RPM);
    15.       //UART_Write_Text(RPM);
    16.    }
    17. //================================================
    18.  void main()
    19.    {
    20.       CMCON = 0x07;   // Disable comparators
    21.       ADCON1 = 0x0F;  // Disable Analog functions
    22.       //TRISC = 0x00;
    23.       TRISC = 0x80;        // Port C output except RC7 RX
    24.       TRISB = 0x00;
    25.       PORTA = 0x00;
    26.       TRISA = 0b00010000;
    27.       T0CON = 0b01101000; // TMR0 as 16-bit counter
    28.       Lcd_Init();        // Initialize LCD
    29.       Lcd_Cmd(_LCD_CLEAR);             // CLEAR display
    30.       Lcd_Cmd(_LCD_CURSOR_OFF);        // Cursor off
    31.       Lcd_Out(1,1,message1);            // Write message1 in 1st row
    32.       //----
    33.        UART1_Init(9600);                         // initialize UART1 module
    34.        Delay_ms(100);
    35.       //----
    36.       do
    37.        {
    38.            T0CON.TMR0ON = 1;
    39.            TMR0L = 0;
    40.            TMR0H = 0;
    41.            IR_Tx = 1;
    42.            Delay_ms(1000); // Wait for 1 sec
    43.            IR_Tx = 0;
    44.            T0CON.TMR0ON = 0;    // Stop the timer
    45.            RPM_Value = (256*TMR0H + TMR0L)*60;
    46.            Display_RPM(RPM_Value);
    47.            //----
    48.
    49.            LongToStr(RPM_Value, txt);
    50.            UART_Write_Text("N");
    51.            Delay_ms(10); // Wait for 1 sec
    52.            //UART_Write_Text("2014TACHY.V3.COM");
    53.            UART_Write_Text(txt);
    54.            //----
    55.        } while(1);             // Infinite Loop
    56.  }
    57.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    It is using timer 0 as a counter and counting the number of slots in the wheel it detects in one second.
    See this website for more information...
    splendid-electron likes this.
  3. splendid-electron
    Jan 26, 2014
    14
    Lcd_Out(2,4,RPM);
    can u explain for me the use of this lines
  4. tshuck
    Oct 18, 2012
    3,531
    675
    Please use code tags when posting code ( the "#" button - it surrounds your code with [CODE ] and [/CODE ] tags. Note that the spaces are there so it is treated as text).
    This code is converting the binary number to ASCII, by taking each number and assigning it to an element in the RPM array, which will then be displayed on a LCD screen.
    ErnieM and splendid-electron like this.
  5. splendid-electron
    Jan 26, 2014
    14
    1.  do
    2.        {
    3.            T0CON.TMR0ON = 1;
    4.            TMR0L = 0;
    5.            TMR0H = 0;
    6.            IR_Tx = 1;
    7.            Delay_ms(1000); // Wait for 1 sec
    8.            IR_Tx = 0;
    9.            T0CON.TMR0ON = 0;    // Stop the timer
    10.            RPM_Value = (256*TMR0H + TMR0L)*60;
    11.            Display_RPM(RPM_Value);
    12.            //----
    Hello :)
    please help me to understand how this can count the number of slots
    specialy this
    1.  RPM_Value = (256*TMR0H + TMR0L)*60;
  6. tshuck
    Oct 18, 2012
    3,531
    675
    The code
    1. 256*TMR0H
    shifts the value in the most significant byte in the counter register 8 bits to the left, which is typically done as
    1. TMR0H<<8
    , but that's not important...
    The shift is needed because the counter is 16 bits, but the registers are 8 bits wide, so you shift the most significant byte into position and add the least significant byte.
    Since this count is over the period of
    1. Delay_ms(1000); // Wait for 1 sec
    this gives us counts per second. Multiplying by 60 gives counts per hour.
  7. splendid-electron
    Jan 26, 2014
    14
    1. T0CON.TMR0ON = 1;
    this line?
  8. tshuck
    Oct 18, 2012
    3,531
    675
    This turns the timer on..
    What is the question?
  9. splendid-electron
    Jan 26, 2014
    14
    what is the functionof this line exactly why 256???
  10. tshuck
    Oct 18, 2012
    3,531
    675
    Did you read post #6?
  11. splendid-electron
    Jan 26, 2014
    14
    aaah yes thank you so much for your help it was helpful :))
  12. splendid-electron
    Jan 26, 2014
    14
    I need a prograam on c# that display the speed via USB on the screen of computer can u help me
  13. tshuck
    Oct 18, 2012
    3,531
    675
    If you are using Visual Studio and WindowsForms, it can be pretty easy if you use a USB to TTL converter.
    Without too much scrutiny, this looks like a good reference.
  14. splendid-electron
    Jan 26, 2014
    14
    thank you so much :)
