Programing a ATtiny2313
Discussion in 'Embedded Systems and Microcontrollers' started by kibodwin, Oct 27, 2010.
  1. kibodwin
    Sep 13, 2010
    13
    I am looking to play around with some micro-controllers and have bought a
    ATtiny2313 chip. I also have access to an arduino and a FTDI FT232RL usb cable. I do not know how I will program / flash the ATtiny 2313 chip.
    Is it possible to use the FTDI cable to flash a ATtiny2313 chip?
    Otherwise I will have to use the arduino. I have goggled and know this is possible but I am having difficulty finding a simple explanation on how to do this. I would be interested if anyone has any simple instructions on how to do this.
    I feel a bit out of my depth but am willing to learn.
    Thank you for any help,
    K.
  2. Bosparra
    Member
    Feb 17, 2010
    79
  3. kibodwin
    Sep 13, 2010
    13
    Thanks for the link, I had found others but no this one!
    update;
    I went through your link and ended up at a tutorial.
    http://arduino.cc/en/Tutorial/ArduinoISP
    This tutorial is to program an arduino with another arduino.
    As I have a ATtiny2313 chip to 'program' am I able to
    use the same method as above or do I need to do something
    different as I am trying to flash / program a different chip?
    Thanks,
    K.
  4. Bosparra
    Member
    Feb 17, 2010
    79
    I suggest you maybe start at the beginning, otherwise you are going to get frustrated. Find a micro controller tutorial and work through it. Familiarise yourself with the datasheet for the 2313, available from Atmels website.
