Program to draw 74HC4060, ATF16V8CZ and 7segment display
Discussion in 'General Electronics Chat' started by Cukrai, Nov 15, 2013.
  1. Cukrai
    Nov 9, 2013
    I need to draw a circuit with these components: 74HC4060, ATF16V8CZ and 7segment display.. I have a Multisim 11 and Eagle 7, however, i cant find any of these components there.. any help with this? maybe i can install a library with more components, or should i use any other program?
  2. t06afre
    May 11, 2009
    It is often with ECAD system that you do not find the symbol you are looking for. Then you have to make by yourself. You can often cut some (a lot) corners by using an existing symbol as template. Eagle is a very popular ECAD system. It is more likely that you may find some ready made symbols for Eagle on the net. Here Google will be your friend.
