professional plasma repair
Discussion in 'Off-Topic' started by sheldons, Dec 6, 2011.
  1. sheldons
    Oct 26, 2011
    616
    101
  2. saturation
    Member
    Dec 21, 2008
    22
    You can do that to LCDs too; if the connector loosens due the heat generated. But I wouldn't be as brutal, just press or rub in the area with the defect.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    I 'll move that to the offtopic section.
  4. sheldons
    Oct 26, 2011
    616
    101
    there is only one way to repair an lcd with that sort of fault -it involves the use of a very expensive machine to repair the affected tab(s) and by the time you have paid for that you could have bought a replacement set.
  5. gerty
    Aug 30, 2007
    1,154
    304
    Wonder how often he has to get his bat calibrated..
  6. sheldons
    Oct 26, 2011
    616
    101
    i offer a reasonable bat calibration service and can supply you with a calibrated pre programmed bat for this very purpose via my ebay account....buy 1 get 1 free at the moment
