Product rule - differentiation
Discussion in 'Math' started by amilton542, Feb 2, 2012.
  1. amilton542
    Thread Starter Active Member
    Nov 13, 2010
    494
    64
    Let's say you've got a product of n different functions, as many as you want it doesn't matter (but not two), I'll choose 5 for simplicity. If I wanted to calculate dy/dx, could I use this method?
    (uvwxz)'= u'vwxz + uv'wxz + uvw'xz + uvwx'z + uvwxz'
  2. Zazoo
    Member
    Jul 27, 2011
    114
    43
    Yes, that works.
    amilton542 likes this.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Are the rest of the functions related to x?
    What you wrote is the derivative of the product. Do you want dy/dx instead?
  4. amilton542
    Nov 13, 2010
    494
    64
    Yes I wanted the derivative of the product.
    I introduced all the new y values and subtracted the old ones to give me the difference in y, then I took the limit when Δx tends to zero, then put it in that notation for a clear visual inspecton.
    Please excuse my terminology, I thought dy/dx was the total rate of instantaneous change e.g. the derivative which can alse be written as (uvwxz)'. Is that correct?
  5. amilton542
    Nov 13, 2010
    494
    64
    Ohhhh rats! I've made an error in the alphabet! How embarrassing. I've used y as notation in the functions, sorry folks!
  6. Zazoo
    Member
    Jul 27, 2011
    114
    43
    As Georacer pointed out, the assumption here is that u, v, w and z are all functions of x themselves (and not separate variables.)
  7. amilton542
    Nov 13, 2010
    494
    64
    When did I say they were seperate variables? An increment in x will cause incremental changes in all functions.
  8. Zazoo
    Member
    Jul 27, 2011
    114
    43
    You didn't, I was just pointing out that my answer was based on that assumption.
