Processor Registers
abhimanyu143
Joined Aug 25, 2014
211
I think that the Nand2Tetris project might be something that you would find very informative. I give an overview of it in one of my blogs, so take a look:
http://forum.allaboutcircuits.com/blog/nand2tetris-overview.590/
yes that's very Informative . But I Think I am too long from this project. I am interested to DO that project . can you give me some idea how can I do that project step by step with very few duration. I don't believe that I can Do such big projects
WBahn
Joined Mar 31, 2012
30,045
I looked that post. I think he is doing course on embedded system designing. he asked about 8051 microcontroller Design. There is degree course in India. In which we read about embedded micro controller. generally we study about what is processor ROM memory , Ram memory , timer , interrupt i/o device and c programming so may be many student ask about microcontroller I don't think that I can design processor without learning basics. Designing processor is also good but very tough idea
for my semester exam I have to learn about 8051 , Pic and ARM controller so that's why I am asking
All the more reason to look at the Nand2Tetris project. If you work through that project diligently, you will have a very good understanding of the basic concepts behind a modern computing system. Not everything and what you do know will be somewhat limited and shallow, but you will be amazed how much more all of this will make sense to you.
WBahn
Joined Mar 31, 2012
30,045
When I did that project from the time that I started downloading the software from their site to the time I had the first five projects completed took about three hours and these are the projects that get at the heart of what you are struggling with here. Don't expect to finish them that fast because I had the advantage of having a solid understanding of these concepts before I started, but the early projects are quite tractable. The later projects become progressively more involved, but you can save those for later.
You can also do the projects in any order, but I recommend doing them in the order presented.
abhimanyu143
Joined Aug 25, 2014
211
Decoder used in processor
Look this link http://en.wikipedia.org/wiki/Decoder
there are two type of decoder
  • Instruction Decoder
  • Address decoder
Instruction Decoder : Instruction decoder is use to decode Instruction
In post 18 , the Instruction is 8 bit . and 256 instruction , To decode 256 instruction I think we need 8x256 Decoder
but there is not sufficient Information In this link about decoder
some one can tell me How does decoder decode instruction?
kubeek
Joined Sep 20, 2005
5,795
Vead, just like I said in the other thread. The decoder is similar to a table, where for each instruction the apropriate outputs connected to control wires that go to each part of the processor are turend on or off.
So for example if the instruction is ADD A the wires are set such that the output of register A is connected to one input of the ALU, accumulator is is connected to the other input and the result will be stored back to the accumulator.
Without talking about some actual design and having it in front of me it is quite hard to explain thing in this abstract manner.
Google how for examle a 3-to-8 decoder works. Now imagine that you have a similar decode wired such that for each instruction the correct control wires are activated. That is the decoder.
abhimanyu143
Joined Aug 25, 2014
211
this link show truth table of decoder http://coep.vlab.co.in/?sub=28&brch=81&sim=609&cnt=1
suppose we have three control wires.
one wire for accumulator
one wire for registers
one wire for memory
Example
3 to 8 decoder
000 no wires are activate
001 memory wire is activate
010 register wire is activate
011 register and memory wires are activate
100 accumulator wire is activate
101 accumulator and memory wires are activated
110 accumulator and register wires are activate
111 all wires are activated
Did you mean like this type of example
output of each instruction is connected with Accumulator
100 LD A
100 ADD A
100 SUB A
100 MUL A
100 AND A
100 OR A
010 LD R
010 ADD R
010 SUB R
010 AND R
010 OR R
absf
Joined Dec 29, 2010
1,968
So you are actually vead. kubeek is much faster than me to recognise you...:p
From your way of writing: "I looked that post" you never use preposition like "at". And
you never terminate a sentence with full-stop. You just start with another line.....etc
What's wrong with the old name "vead". Are you scared that no one would help you if you continue using the old name?
Dont worry about how we can sometimes get frustrated helping members. But after a while everything will be back to normal and we'll be helping again. This happens all the time.;)
Allen
abhimanyu143
Joined Aug 25, 2014
211
Allen
Am I need to proof That I am abhimanyu.? the post is on same topic but I already said that there are many student that are studying course on embedded system in india
so topic may be same and yes I don't understand English very well I except that there are many similarity between me and that guy because we both belong to same place India. even doing same degree course
there are many student that face this problem
abhimanyu143
Joined Aug 25, 2014
211
I have only 4 topics to read then I will start PiC controller
timer
interrupt
uart
A to D converter
Interrupt an interrupt is a signal to the processor emitted by hardware
Hardware interrupts are used by devices to communicate that they require attention from the operating system.
link http://en.wikipedia.org/wiki/Interrupt
How does interrupt generate in microcontroller circuit ?
absf
Joined Dec 29, 2010
1,968
I apologize if you are not vead. Please don't get upset about this...:oops:
Anyway, AAC is a very nice forum where members here are very helpful and friendly. I hope you'll have a present stay and learn as much as you wish...:)
Allen
kubeek
Joined Sep 20, 2005
5,795
Interrupt sets a certain bit in Status register. At the beginning of each instruction cycle the controller check this bit, and if it is set then instead of fetching the next intruction it stores Program counter to some known location (so that it can later go back to where it left) and starts exectuing the intructions for the interrupt. After the interrupt routine finishes, the previously stored program counter is restored and the normal program continues.
abhimanyu143
Joined Aug 25, 2014
211
post 27 about Instruction decoder
one wire for memory
Example
3 to 8 decoder
100 LD A
100 ADD A
100 SUB A
100 MUL A
100 AND A
100 OR A
010 LD R
010 ADD R
010 SUB R
010 AND R
010 OR R
Did you mean like this?
kubeek
Joined Sep 20, 2005
5,795
Do I mean what like what? I cant keep track of this thread if you keep jumping from subject to subject. Focus on one part and lets talk abou that.
abhimanyu143
Joined Aug 25, 2014
211
I am talking about only Instruction decoder
I think this two link may be useful
3. Decode Instruction Phase http://www.c-jump.com/CIS77/CPU/InstrCycle/lecture.html
So for example if the instruction is ADD A the wires are set such that the output of register A is connected to one input of the ALU, accumulator is is connected to the other input and the result will be stored back to the accumulator..
I am trying to do something from 1 st link
one wire for memory
Example
3 to 8 decoder
100 LD A
100 ADD A
100 SUB A
100 MUL A
100 AND A
100 OR A
010 LD R
010 ADD R
010 SUB R
010 AND R
010 OR R
I am trying to understand Instruction decoder . I understood truth table of decoder But I am not understanding how does instruction decoder decode instruction and how does particular source or destination turn on/off
kubeek
Joined Sep 20, 2005
5,795
Look at this diagram http://www.nt-nv.fh-koeln.de/Labor/VhdlEnglish/Kap8/k832.html Near the bottom you can see which control wires are activated for each instruction opcode.
And here is VHDL code for it
Code:
-- VHDL-Modell der TOY-Simulation -----------------------------------
PACKAGE a2 IS
TYPE ltg IS ARRAY(1 TO 2) OF integer;
END a2;
-- VHDL-Beschreibung der ALUaccu
ENTITY ALUaccu IS
   GENERIC(T : Time := 4 ns);
   PORT(ramdat, alucon : IN ltg;
        aluout   : OUT ltg;
        nullflag : OUT integer);
END ALUaccu;
ARCHITECTURE behaviour OF ALUaccu IS
BEGIN
   PROCESS
   TYPE word IS ARRAY(1 TO 16) OF integer;
   VARIABLE oldclk, adress, opcode, adi, opi, opo, ado : integer :=0;
   VARIABLE oldalucon, vopout, vadout, temp, i, j : integer :=0;
   VARIABLE acbit, rambit, outbit : word;
   BEGIN
     IF alucon(1) /= oldalucon THEN
       temp:=ado;
       FOR j IN 1 TO 12 LOOP
         IF temp < 1 THEN
           acbit(j):=0;
         ELSE
           acbit(j):=temp MOD 2; temp:=(temp-(temp MOD 2))/2;
         END IF;
       END LOOP;
       temp:=opo;
       FOR j IN 13 TO 16 LOOP
         IF temp < 1 THEN
           acbit(j):=0;
         ELSE
         END IF;
       END LOOP;
       temp:=ramdat(2);
         IF temp < 1 THEN
           rambit(j):=0;
         ELSE
           rambit(j):=temp MOD 2; temp:=(temp-(temp MOD 2))/2;
         END IF;
       END LOOP;
       temp:=ramdat(1)
         IF temp < 1 THEN
           rambit(j):=0;
         ELSE
         END IF;
       END LOOP;
       IF alucon(1)=12 THEN vopout:=opo; vadout:=ado;
       ELSIF alucon(1)=1 THEN
         vopout:=ramdat(1); vadout:=ramdat(2);
       ELSIF alucon(1)=3 THEN
         vopout:=opo+ramdat(1); vadout:=ado+ramdat(2);
       ELSIF alucon(1)=4 THEN
         vopout:=opo-ramdat(1); vadout:=ado-ramdat(2);
       ELSIF alucon(1)=5 THEN
         FOR i IN 1 TO 16 LOOP
           IF (acbit(i)=1) OR rambit(i)=1) THEN
             outbit(i):=1;
           ELSE
             outbit(i):=0;
           END IF;
         END LOOP;
       ELSIF alucon(1)=6
           IF (acbit(i)=1) AND rambit(i)=1) THEN
             outbit(i):=1;
           ELSE
             outbit(i):=0;
           END IF;
         END LOOP;
       ELSIF alucon(1)=7
           IF (acbit(i)=1) /= rambit(i)=1) THEN
             outbit(i):=1;
           ELSE
             outbit(i):=0;
           END IF;
         END LOOP;
       ELSIF alucon(1)=8
           IF (acbit(i)=1) = rambit(i)=1) THEN
             outbit(i):=1;
           ELSE
             outbit(i):=0;
           END IF;
         END LOOP;
       ELSIF alucon(1)=9  THEN vopout:=opo; vadout:=ado+1;
       ELSIF alucon(1)=10 THEN vopout:=opo; vadout:=ado-1;
       ELSIF alucon(1)=11 THEN vopout:=0; vadout:=0;
     END IF;
   END IF;
   IF alucon(1)>4 AND alucon(1)<9 THEN
     vadout:=0;
     FOR i IN 1 TO 12 LOOP
       vadout:=vadout + (outbit(i)*(2**(i-1)));
     END LOOP; vopout := 0;
     FOR i IN 13 TO 16 LOOP
       vopout:=vopout + (outbit(i)*(2**(i-13)));
     END LOOP;
   END IF;
   oldalucon:=alucon(1);
   IF alucon(2) =1 AND oldclk=0 THEN
     opo:=vopout; ado:= vadout;
   END IF;
   IF opo=0 AND ado=0 THEN
     nullflag<=1 AFTER T;
   ELSE
     nullflag<=0 AFTER T;
   END IF;
   oldclk:=alucon(2); aluout(1)<=vopout AFTER T; aluout(2) <= vadout AFTER T;
   END PROCESS;
END behaviour;
-- VHDL-Beschreibung des Programmzaehlers (PC)
ENTITY PC IS
   GENERIC(T : Time := 4ns);
   PORT(iri, nflag : IN integer;
        clock : IN ltg;
         outa : OUT integer);
END PC;
ARCHITECTURE behaviour OF PC IS
BEGIN
   PROCESS
   VARIABLE addr, oldclock, oldsddr, oldinc : integer:=0;
   BEGIN
     IF clock(1)=1 AND oldclock=0 AND nflag=1 THEN
       addr:=iri;
     END IF;
     IF clock(2)=1 AND oldinc=0 THEN
       addr:=(oldaddr+1);
     END IF;
     outa<=addr AFTER T;
     oldclock:=clock(1);
     oldaddr:=addr;
     oldinc:=clock(2);
     END PROCESS;
END behaviour;
-- VHDL-Beschreibung des Multiplexers (Mux)
ENTITY Mux IS
   GENERIC(T : Time := 2ns);
   PORT(ir, pc : IN integer;
        addrir : IN ltg;
        adout : OUT integer);
END Mux;
ARCHITECTURE behaviour OF Mux IS
BEGIN
   PROCESS
   VARIABLE oldaddrir, vout, oldaddrpc : integer:=0;
   BEGIN
     IF addrir(1)=1 AND oldaddrir=0 THEN
       vout:=ir;
     END IF;
     IF addrir(2)=1 AND oldaddrpc=0 THEN
       vout:=pc;
     END IF;
     adout<=vout AFTER T;
     oldaddrir:=addrir(1);
     oldaddrpc:=addrir(2);
   END PROCESS;
END behaviour;
-- VHDL-Beschreibung des Befehlsregisters (IR)
ENTITY IR IS
   PORT(ramin : IN ltg;
        clockir : IN integer;
        opcon, adpc: OUT integer);
END IR;
ARCHITECTURE behaviour OF IR IS
BEGIN
   PROCESS
   VARIABLE oldclockir, vadpc, vopcon : integer := 0;
   BEGIN
     IF clockir=1 AND oldclockir=0 THEN
       vadpc:=ramin(2);
       vopcon:=ramin(1);
     END IF
     adpc <= vadpc AFTER T;
     opcon <= vopcon AFTER T;
     oldclockir:=clockir;
   END PROCESS;
END behaviour;
-- VHDL-Beschreibung des Steuerwerks (Control)
ENTITY Control IS
   PORT(opco, takt : IN integer;
        clir, wriram : OUT integer;
        alcon, adir, clpc : OUT ltg);
END Control;
ARCHITECTURE behaviour OF Control IS
BEGIN
   PROCESS
   VARIABLE oldtakt, vclac, vclir, valcon, vadir : integer;
   VARIABLE vadpc, count, vclpc : integer;
   VARIABLE vwriram, vincpc, anfang : integer;
   BEGIN
   IF takt=1 AND oldtakt=0 AND count=0
     IF opco=12 THEN
        vadir:=1; vadpc:=0; valcon:=opco; vwriram:=1;
        vclac:=0; vclir:=0; vclpc:=0; vincpc:=0;
     ELSIF opco=1 THEN
        vadir:=1; vadpc:=0; valcon:=opco; vwriram:=0;
        vclac:=1; vclir:=0; vclpc:=0; vincpc:=0;
     ELSIF opco=2 THEN
        vadir:=0; vadpc:=1; valcon:=opco; vwriram:=0;
        vclac:=0; vclir:=0; vclpc:=1; vincpc:=0;
     ELSIF opco>2 AND opco<8 then
     ELSIF opco=8 THEN
     ELSIF opco=9 THEN
        vadir:=0; vadpc:=0; valcon:=opco; vwriram:=0;
     ELSIF opco=10 THEN
     ELSIF opco=11 THEN
     ELSIF opco=0 OR opco>12 THEN
       IF anfang=0 THEN
         vadpc:=0; vclir:=1;
         vincpc:=1; anfang:=1;
       ELSE
         vclac:=0; vclir:=1; vclpc:=0; vincpc:=1;
       END IF;
     END IF;
   END IF;
   IF takt=1 AND oldtakt=0 AND count=1 THEN
     vadir:=0; vadpc:=1; vclir:=1; vincpc:=1;
     valcon:=0; vwriram:=0; vclac:=0; vclpc:=0;
   END IF;
   IF takt=1 AND oldtakt=0 AND opco<13 AND opco>0 AND count=0 THEN
     count:=1;
   ELSIF takt=1 AND oldtakt=0 THEN
     count:=0;
   END IF;
   IF takt=0 AND oldtakt=1 THEN
     vadir:=0; vadpc:=0; valcon:=0; vwriram:=0;
   END IF;
   adir(1) <= vadir AFTER T;
   adir(2) <= vadpc AFTER T;
   alcon(1)<=valcon AFTER T + 12 ns;
   wriram<=vwriram AFTER T+16 ns;
   alucon(2) <=vclac AFTER T+12 ns;
   clir <= vclir AFTER T + 15 ns;
   clpc(2)<=vinpc AFTER T + 16 ns;
   clpc(1)<= vclpc AFTER T + 16 ns;
   oldtakt:=t;
   END PROCESS;
END behaviour;
kubeek
Joined Sep 20, 2005
5,795
And the second half of the code.
Code:
-- VHDL-Beschreibung des Speicherbausteins (RAM)
ENTITY RAM IS
   PORT(admux, write : IN integer;
        datin  : IN ltg;
        datout : OUT ltg);
END RAM;
ARCHITECTURE behaviour OF RAM IS
BEGIN
   PROCESS
   TYPE word IS ARRAY (1 TO 25) OF integer;
   VARIABLE opwort, adwort : word;
   VARIABLE oldwrite, oldadresse, adresse : integer;
   VARIABLE start, vadrout, vopcout : integer;
   BEGIN
   IF start=0 THEN
     opwort(1):=1;
     adwort(1):=12;
     opwort(2):=12;
     adwort(2):=15;
     opwort(3):=1;
     adwort(3):=15;
     opwort(4):=10;
     adwort(4):=0;
     opwort(5):=2;
     adwort(5):=16;
     opwort(6):=12;
     adwort(6):=15;
     opwort(7):=1;
     adwort(7):=12;
     opwort(8):=3;
     adwort(8):=13;
     opwort(9):=12;
     adwort(9):=14;
     opwort(10):=11;
     adwort(10):=0;
     opwort(11):=2;
     adwort(11):=3;
     opwort(12):=0;
     adwort(12):=2;
     opwort(13):=0;
     adwort(13):=2;
     start:=1;
     END IF;
     adresse:=admux;
     IF write=1 AND oldwrite=0 THEN
       opwort(adresse):=datin(1);
       adwort(adresse):=datin(2);
     END IF;
     IF adresse/=oldadresse THEN
       vopcout:=opwort(adresse);
       vadrout:=adwort(adresse);
     END IF;
     datout(1) <= vopcout AFTER T;
     datout(2) <= vadrout AFTER T;
     oldwrite:=write;
     oldadresse:=adresse;
   END PROCESS;
END behaviour;
-- VHDL-Beschreibung des Taktgenerators (clock)
ENTITY clock IS
   GENERIC(T : Time := 60ns);
   PORT(beat : OUT integer);
END clock;
ARCHITECTURE behaviour OF Clock IS
BEGIN
   PROCESS
       variable oldtakt : integer;
   BEGIN
       IF oldtakt=1 THEN
       beat <= 0 AFTER T/2;
       ELSE
       beat <= 1 AFTER T/2;
       END IF;
   oldtakt := beat;
   END PROCESS;
END behaviour;
-- Strukturmodell des gesamten Rechners "TOY"
ENTITY TOY IS
END TOY;
ARCHITECTURE structure OF TOY IS
      SIGNAL OPCONIR, ADIR, ACUNFL, ADPCMUX, ADMUXRAM, CONCL, CLIR,
             WRITERAM, : integer;
      SIGNAL ALUOUT, ALUCON, RAMOUT, MUXCON, CLOCKPC : ltg;
    COMPONENT ALUaccu
             nullflag : OUT integer; aluout : OUT ltg);
    END COMPONENT;
    COMPONENT Mux
        PORT(ir, pc : IN integer; addrir : IN ltg;
    END COMPONENT;
    COMPONENT PC
        PORT(iri, nflag : IN integer; clock: IN ltg;
    END COMPONENT;
    COMPONENT IR
        PORT(clockir : IN integer; ramin : IN ltg;
                 opcn, adpc : OUT integer);
    END COMPONENT;
    COMPONENT RAM
        PORT(admux, write : IN integer; datin  : IN ltg;
             datout : OUT ltg);
    END COMPONENT;
    COMPONENT Control
    END COMPONENT;
    COMPONENT Clock
    END COMPONENT;
BEGIN
    ALUaccu : ALUaccu
        PORT MAP(ramdat=>RAMOUT, nullflag=>ACUNFL,
            aluout=>ALUOUT, alucon=>ALUCON);
    END ALUaccu;
    RAM : RAM
        PORT MAP(datin=>ALUOUT, admux=>ADMUXRAM,
            write=>WRITERAM, datout=>RAMOUT);
    END RAM;
    IR : IR
        PORT MAP(ramin=>RAMOUT, clockir=>CLIR,
            opcn=>OPCONIR, adpc=>ADIR);
    END IR;
    PC : PC
        PORT MAP(iri=>ADIR, clock=>CLOCKPC,
            nflag=>ACUNFL, outa=>ADPCMUX);
    END PC;
    Mux : Mux
        PORT MAP(ir=>ADIR, pc=>ADPCMUX, addrir=>MUXCON,
                adout=>ADMUXRAM);
    END Mux;
    Control : Control
        PORT MAP(opco=>OPCONIR, takt=>CONCL, clir=>CLIR,
                alcon=>ALUCON, adir=>MUXCON, clpc=>CLOCKPC,
                wriram=>WRITERAM);
    END Control;
    Clock : Clock
        PORT MAP(beat => CONCL);
    END Clock;
END structure;
