I suspect you are seeing two things. First, you are once again inserting the ON resistance into the part of the circuit that produces the measurement, which desensitizes the measurement. You want the MUX on the high side of the thermistors. Second, you are probably reducing the current output of your current source because of a low output impedance. We have already determined that the resistance of the MUX channels is about 500Ω and that, near room temperature, the resistance of the thermistor is about 120Ω, or 620Ω total. If you are only seeing 760mA across the combination, then you only have about 1.1mA of current.
