Problems with Samsung C460FW and wireless network
Discussion in 'Computing and Networks' started by bertus, Jan 19, 2016.
  1. bertus
    Thread Starter Administrator
    Apr 5, 2008
    15,806
    2,389
    I have a Samsung C460FW and a Netgear WNDR4300V2.
    All worked fine untill we tried to access the scanner over wifi on the windows 10 laptop of my wife.
    The scanner app did see the scanner.
    We tried to get a preview.
    The printer/scanner made some noise
    But afterwards the wifi connection is lost and I can not get it up again.
    The scanner app will not see the scanner anymore as the connection is lost.
    All other activities via wifi on the printer/scanner fail.
    When I press the WPS button on the printer, it asks to press the WPS button on the access point.
    The blue light on the printer blinks, but goes off after the time-out of 2 minutes.
    What can I do?
    Bertus
  2. shteii01
    Feb 19, 2010
    3,515
    515
    Since WPS failed, do the manual setup of the printer.
    I also have Samsung printer/scanner (different model). Hook it up, using usb, to pc/laptop, run the setup program/utility, it will let you tell the printer/scanner the wifi stuff like ssid, encryption, wifi password.
  3. shteii01
    Feb 19, 2010
    3,515
    515
  4. bertus
    Apr 5, 2008
    15,806
    2,389
    The firmware update program does not work.
    You can not select the firmwarefile.
    I now connected the printer to the router using an utp cable.
    Now I can access the printer and scanner from the both laptops and the main linux PC.
    Bertus
