I have the picKit 2 and it works... with some chips. I've been using the pic16F688 device and it has been working fine. However, when I plug in a dsPIC33J12MC201 (why are the names so long?) or a PIC24F08KA101 I get an error in MPLAB saying
PKWarn0003: Unexpected device ID: Please verify that a dsPIC33FJ12MC201 is correctly installed in the application. (Expected ID = 0x8000000, ID Read = 0x0)
PK2Error0049: VPP Voltage error. Check target and retry operation.
I get a similar voltage error when I try the pickit software. Also the same error when I try the other pic24 chip. It seems that it is not recognizing the devices at all (Read 0x0). I have no idea why.
The pickit 2 supported devices list lists both chips as compatible with both MPLAB and Pickit2 software yet it doesn't work on either.
