Problems with mosfet
Discussion in 'General Electronics Chat' started by jakethehusky, Mar 28, 2016.
  1. jakethehusky
    Mar 24, 2016
    22
    Hey
    I was working on a little project to control rgb leds with an Arduino, however it can't work directly with the Arduino (to high current) so I asked my local electronic shop for some mosfets that would do the job.
    However I am unable to get it working.
    On the mosfet itself it has 3 lines of text,
    IRLZ44N
    I*R P513P
    WA9Y
    But the bill says IRFZ44N N-Ch 55. Did they gave me the wrong ones ?
    To test it I used a simple circuit, The arduino's digital output connected with the gate of the mosfet, the drain to the positive side of my DC power supply unit and the source to a led that is than connected to the ground of my DC power supply.
    Like this the led stays on, no matter what I do,
    EDIT: I have already tried reversing drain and source, same result
  2. kubeek
    Sep 20, 2005
    4,691
    806
    Probably, but those two are so close that I wouldn´t worry.
    As for your problem, it is an N channel fet, so you would want your LED and the resistor connected between +V and drain, and the source connected to gnd.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Therein lies most of your problem. The LED should be connected to the positive supply, the cathode (negative) side of the LED should go to the mosfet drain, and the mosfet source should go to ground.
    You should also the the "L" version, which take less voltage to turn it on. The L version will turn on quite well at just 3 volts gate-source. It is fully characterized at 4 volts.
    John
  4. jakethehusky
    Mar 24, 2016
    22
    Well I have changed my test a little, I connected my pwm pin from my Arduino to the gate. The led is connected to the drain and to the positive side and the source is connected to the negative side.
    When I connect the positive side and the negative side to the +5V and GND from the Arduino it works. but when I connect the positive and negative to my DC power supply unit it just stays on.
  5. kubeek
    Sep 20, 2005
    4,691
    806
    Can you draw a schematic of that? a picture is worth a thousand words.
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    The arduino and power supply must have a common ground. That is, the ground of the power supply and arduino must be connected together.
    And yes, a schematic always helps to avoid confusion.
    John
    jakethehusky likes this.
  7. crutschow
    Mar 14, 2008
    13,523
    3,392
    Are you sure you have the correct pinout of the MOSFET?
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    This is the sentence I focused on.
    The fact that it works with the arduino supply is strongly suggestive that the pin assignments are correct. Nowhere does the TS mention connecting the two negative (common) rails.
    John
  9. ian field
    Distinguished Member
    Oct 27, 2012
    4,460
    792
    Reversing source and drain would forward bias the parasitic "body diode".
    An unconnected gate has capacitance that can store a static charge that keeps it switched on.
    In theory; MOSFETs can be damaged by static charges - but I've only had a small number of failures, YMMV.
  10. jakethehusky
    Mar 24, 2016
    22
    Thanks for all the help guys, connecting the ground of my Arduino to the ground of the DC power supply fixed my problem. Even though it works here is a schematic : 935086293b50cbb5ad60870183671e85.png
  11. jpanhalt
    Jan 18, 2008
    5,699
    909
    Hi Jake,
    Glad it worked for you. Now for some details to consider. If you are really using just 3V instead of 4.5 to 5V, the non-L mosfet might get warm.
    Second, you need to consider what happens when voltage is first applied. I am only familiar with PIC's, not arduino, so these comments may not apply to you. Check the state of the pin (datasheet) when power is applied. With PIC's, it is unknown, and they are default analog inputs. I put a turn-off resistor from the gate to ground to insure the mosfet stays off until I turn it on. Also,the gate of a mosfet acts like a capacitor. If it is discharged (i.e., off) the initial inrush of current may be more than is desired for the arduino driver. Of course, that burst is short and may not cause damage; however, I usually put a current limiting resistor between the gate and the driving pin. Here is a typical circuit I use:
    R2 is the turn-off resistor and R1 is the current limiting resistor. R1 is 200 Ω, which limits current at 5 V to about 25 mA . Of course, it slows down the mosfet turn on, but that should not be a problem in your application. As they say, these details are offered with an overabundance of caution. Component values are not critical.
    John
  12. jakethehusky
    Mar 24, 2016
    22
    I'll probably put in some pull down resistors, but I will be using it for controlling an rgb led strip, so that's why I need mosfets. But thanks everyone for the great help !
