Problems with L298
Discussion in 'General Electronics Chat' started by alexx_88, May 24, 2010.
  1. alexx_88
    May 24, 2010
    17
    Hello!
    I am currently working on a first project, designing and implementing a Cruise Control Adaptive system for a toy car. I am having problems in getting the L298 to work.
    I have measured the following inputs on the L298:
    Pin 4 - Vs - 8.3V
    Pin 9 - Vcc - 4.9V
    Pin 11 - Enable B - 4.9V
    Pin 10 - Input 3 - 0V
    Pin 12 - Input 4 - 4.9 V
    When measuring between pins 13 and 14 (Out 3 and Out 4) it reads 0V. I've connected both sense A and sense B directly to ground.
    I've also changed the L298 once, thinking that I've installed a faulty chip. I am running out of ideas :(.
    Alex
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Can you post the board and schematic as .png format?
    Perhaps a screenshot will do.
    I can not read the attachments as they are.
    Bertus
  3. alexx_88
    May 24, 2010
    17
    I have modified my first post.
    Alex
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Hi Alex,
    Did you install the L298 from the bottom of the board? I ask this because you used the mirror image function on the L298. If you inserted it from the top of the board, all of the pin connections will be reversed.
    [eta]
    Don't forget to look at the saturation voltage drop.
    At 1A, you'll lose about 3.2v, at 2A you'll lose around 4.9v in the bridge itself.
  5. alexx_88
    May 24, 2010
    17
    I think you are a GENIUS! :) I installed the two L298s from the top of the board, forgetting (not noticing) that I mirrored the component when I designed the PCB.
    Unfortunately, I have quite a workload these days so the closest day I could think of for testing the L298 is Thursday night. I don't see any reason for it not to work though.
    Thank you again!
    Alex
  6. alexx_88
    May 24, 2010
    17
    I have put the L298 from the bottom of the board and it works perfectly. After I'll complete my project I will post a few more details in the dedicated section.
    Thank you for your help!
    Alex
