Problems with halogen lamp.
Discussion in 'General Electronics Chat' started by Thor55, Oct 16, 2010.
  1. Thor55
    Oct 16, 2010
    I have a halogen pole lamp that just went out. I suspect the switch (with dimmer).
    How do I disassemble unit to get to switch?
    What do I look for on switch? (Burnt wire , etc.)
    Is the switch common hardware store item?
    I replaced the bulb (no finger prints) and it blew when I turned unit on.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    You just hijacked an existing thread with a completely different subject.
    Now you have a thread of your own.
    Bertus
  3. roadey_carl
    Jun 5, 2009
    116
    5
    what kind of halogen lamp is it? extra low voltage or mains? Are you useing a dimmer switch or a normal light switch? what sort of light fitting does the lamp fit in to?
