Problems with H bridge
Discussion in 'The Projects Forum' started by keets, Mar 16, 2013.
  1. keets
    Aug 29, 2009
    5
    I am trying to drive 24v 120w dc motor using H-bridge of IRF840 driven by IR2110.at Appr.=11khz pwm frequency.I am using PIC184431 to control the motor.
    I am using 22.1184 mhz crystal & PR2=124 with timer2 prescaler =4.
    The circuit works fine.
    But I encounter following problems.
    1. At resistive loads it works fine i.e I can get linear dc o/p from 0 to 23 corresponding to 0% to 95% of duty cycle. But when motor is connected it doesn't start till duty cycle = appr.40%.then I get the linearity.
    2. The circuit works fine at lighter loads.At higher load the mosfets get heated up and even at 95% of duty cycle unable to carry the load.
    Please help.
  2. John P
    Oct 14, 2008
    1,638
    225
    I think you have a very bad choice of MOSFET. The data sheet for the IRF840 says it has a channel resistance of .85 ohms, and if you want to run several amps through it, you will certainly see some heating. Also your motor won't get the full voltage because so much is being lost driving current through the FETs.
  3. keets
    Aug 29, 2009
    5
    Sir,
    Will you please suggest one?
  4. John P
    Oct 14, 2008
    1,638
    225
    All right, the Infineon IPB230N06L3 G. 56 cents at Mouser Electronics, 23 milliohms resistance. I haven't checked all the data for you, but this is the kind of thing to look for.
    http://tinyurl.com/ctpmp4z
  5. keets
    Aug 29, 2009
    5
    Thank you for your suggestion.
    Sir what is the reason for my 1st problem? Is it related to high channel resistance? or anything else? i.e. I can measure only 1.5v at motor terminals at 50% duty cycle and there onwards it goes up to 16v at 99% of duty cycle.
  6. John P
    Oct 14, 2008
    1,638
    225
    How much current is flowing with either the resistive load or the motor? And is the motor running free or is it loaded down with something?
  7. keets
    Aug 29, 2009
    5
    current flowing is 2a. & MOTOR has to overcome spring load.
  8. John P
    Oct 14, 2008
    1,638
    225
    You haven't said whether energy is stored in the spring, and whether the motor has an increasing load. And then if it's an H-bridge you must want to reverse the motor. What happens when it goes the other way?
  9. keets
    Aug 29, 2009
    5
    yes energy is stored . Basically it dooor open -close application.
