Problems with class A design
Discussion in 'The Projects Forum' started by cariba, Apr 28, 2009.
  1. cariba
    Apr 22, 2009
    19
    :confused:Hi, i'm doing a class A amplifier and a problem turned out that it is clipping very strangely on the negative cycle when a sine wave is applied. please find the attached picture of the wave at the output and the final power stage i am using, the transistor is a tip132
    Regards
    Alistair
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    Do you use an input coupling capacitor? Either the bias is insufficient, or it's being overridden by your signal source.
    With no input signal, the bias should be adjusted so the emitter is at about half the supply voltage.
    Eric
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    If the transistor is very powerful then it can pull the voltage across the speaker up.
    But the 150 ohms resistor value is much too high to pull the voltage across the speaker down.
    Usually a class-A amplifier uses a constant current source at its output instead of your 150 ohm resistor. The current source must provide at least the peak current of the speaker all the time so it wastes a lot of power getting very hot.
    The power transistor supplies double the current used by the speaker.
  4. cariba
    Apr 22, 2009
    19
    Yes i'm using a coupling capacitor and the circuit is well balanced. What do you mean by insuffiecient bias? base bias or collector bias?
    Regards
    Alistair
  5. cariba
    Apr 22, 2009
    19
    Hi audio guru , can you please give ma abreif sketch of how I should apply the current source at the final stage please, i am using a 70v supply and a 8 ohm speaker load.
    regards
    Alistair
  6. Ron H
    Apr 14, 2005
    7,050
    657
    As an example, if you expect your output voltage to swing ±800mV, then on the positive peak the emitter follower must supply a current of 100mA, plus whatever flows through the resistor. However, on the negative peak, 100mA must flow back toward the emitter. Since the emitter can't sink current, that current must be provided by the resistor. If the resistor is too large, the emitter follower will cut off (the base voltage will swing lower than the emitter voltage), which is what you are seeing.
  7. PRS
    Aug 24, 2008
    989
    35
    Please show how your supply voltage is hooked up.
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    A class-a amplifier with a 70V supply will produce a max output of about 65V p-p. then the peak current into 8 ohms is 4.1A. The output devices must always pass about 3.2A so they heat with a total of 224W or more.
    The max continuous output to the speaker is only 66W at clipping.
    Here is an article about a class-A amplifier. The final version has an output of 20W and gets very hot. http://sound.westhost.com/project36.htm
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The body diode will cause large problems.
    Choose a power transistor that doesn't have a body diode.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    It's reverse-biased. Please explain.
  11. cariba
    Apr 22, 2009
    19
    Oh my goid what a power loss:( and so how can I make this continous 3.2a continous current flow without having a resistor, should i use a current source ? or i am ploughing lol
  12. cariba
    Apr 22, 2009
    19
    the main problem is that I couldnt find a resistor which is capable of handling all that power, maybe I could use some type of configuration which acts the same as a resistor load.
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    Didn't you see the class-A amplifier project in my link? It uses a power transistor in its amplifying section and uses another power transistor as its constant current source.
    Why do you want to waste electricity and to heat your entire neighbourhood with a class-A amplifier? Why not use a very good and cool class-AB amplifier?
  14. Ron H
    Apr 14, 2005
    7,050
    657
    SgtWookie must have me on his Ignore list.:rolleyes:
  15. PRS
    Aug 24, 2008
    989
    35
    I made a big 8 ohm power resistor by putting many 10 watt (ceramic-insulator) 100 ohm resistors in parallel. I have it on an insulating plate on my workbench. May I ask, Cariba, what you are using as a supply? And what are you driving this power amp with. What is the output resistance of your driver?
  16. cariba
    Apr 22, 2009
    19
    Hi paul, I have managed to set up a combination of power resistors to get 8 ohm, altough they heatup they radiate heat very well. and the power stage is perfect now.
    DOnt know if I had the problem before but it seems strange because as i connect the signal generator into the va stages of which i have 2 , the first stage that its input is coupled to the generator is loosing its dc biasing:(
    I have replaced the capacitor and its still loosing biasing even with the lead connected and zero input amplitude:(
    Any ideas to my problem please??
    Regards
  17. PRS
    Aug 24, 2008
    989
    35
    Could be the power amp is pulling alot of current from the stage that's driving it. This is common. You might want to include a driver stage between your voltage amplifiers and your power amp. This could be another Darlington set up as an emitter follower. Bias the base between your supply voltages using identical resistors for R1 and R2.
    I'd like to add, Cariba that I have an audio amp project going now which is similar to yours. I think I posted my power amp. It was working just beautifully -- no distortion. Then it went kaput. I think my cat shorted something out and I turned it on and zapped something. Back to work....
  18. cariba
    Apr 22, 2009
    19
    thats what i did mate, and everythings fine now, i just have the supply riplle which is to loud since its being amplified as noise, now i `ll try to set up an indepeandant suplly for the va stages.
    AHHHHH damm itt, u shall microwave your cat then :mad:
  19. PRS
    Aug 24, 2008
    989
    35
    My cat is too cute to do that to. He's a little black kitten that fits in my boot. I give him slack. As for your ripple, I'm having the same problem. Thing is the fixes all seem to lead to reducing the maximum peak to peak voltage. Any ideas?
