Problems with audio controller
Discussion in 'Embedded Systems and Microcontrollers' started by NSCC_EETN, Mar 8, 2011.
  1. NSCC_EETN
    Oct 6, 2010
    17
    We are having an issue with our audio controller and we are looking for some assistance. We're using a configuration of 10 keys with a speaker output using a PIC16f887. For some reason we are not getting any sound out of the speaker when a button is pressed.
    What we are trying to do is have one key output a particular frequency using Timer0 to the speaker. For some reason the code is not working as it should and we are stumped as to find a solution.
    We think it might have to do with the interrupt routine at the top of the programming, but are not 100% sure. If someone could help us that would be appreciated as we are behind schedule trying to work this tiny kink out of our project.
    Code ( (Unknown Language)):
    1.
    2. ;********************** Header ***************************************************
    3.
    4.   LIST R=DEC                   ; list directive to define processor
    5.  INCLUDE "p16f887.inc"           ; processor specific variable definitions
    6.
    7.     __CONFIG  _CONFIG1, _HS_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOR_ON & _IESO_ON & _FCMEN_ON & _LVP_OFF & _DEBUG_OFF
    8. __CONFIG _CONFIG2, _BOR40V & _WRT_OFF
    9. ;************* DEFINING VARIABLES ************************************************
    10.
    11.        cblock      0x20            ; Block of variables starts at address 20h
    12.        w_temp                      ; Variable at address 20h
    13.        pclath_temp                 ; Variable at address 21h
    14.        status_temp                 ; Variable at address 22h
    15.        endc
    16.
    17. ;************************ PROGRAM START ******************************************
    18.        org         0x0000          ; Address of the first program instruction
    19.        goto        setup            ; Jump to label "setup"
    20.
    21. ;************************ INTERRUPT ROUTINE **************************************
    22.
    23.        org         0x0004          ; Interrupt vector
    24.        movwf       w_temp          ; Saves value in register W
    25.        movf        STATUS          ; Saves value in register STATUS
    26.        movwf       status_temp
    27.        movf        PCLATH          ; Saves value in register PCLATH
    28.        movwf       pclath_temp
    29.
    30.
    31.
    32.        movf        pclath_temp,w   ; PCLATH is given its original content
    33.        movwf       PCLATH
    34.        movf        status_temp,w   ; STATUS is given its original content
    35.        movwf       STATUS
    36.        swapf       w_temp,f        ; W is given its original content
    37.        swapf       w_temp,w
    38.
    39.        bsf         INTCON,GIE      ; Global interrupt enabled
    40.
    41.        retfie                      ; Return from interrupt routine
    42.
    43.  ;*********************************setup**********************************************
    44. setup
    45.  banksel ANSEL
    46.    clrf ANSEL                           ;set PORTA as digital
    47.    clrf ANSELH
    48.  banksel TRISA
    49.    bsf   TRISA, 0
    50.    bsf   TRISA, 1
    51.    bsf   TRISA, 2
    52.    bcf   TRISB, 7
    53.    bsf OSCCON,0                           ;make program clock internal
    54.    bcf OSCCON,6
    55.    bcf OSCCON,5
    56.    bcf OSCCON,4                           ;make frequncy 31Khz
    57.    clrf PORTD
    58.    clrf PORTC
    59.    clrf PORTB
    60. ;************************ MAIN PROGRAM *******************************************
    61. main                               ; Start of the main program
    62.
    63.    btfsc PORTA, 0                    ;check to see if the C key is pressed
    64.    call noteC                        ;if so start note
    65.
    66.    btfsc PORTA, 1                    ;check to see if the D key is pressed
    67.    call noteD                        ;if so start note
    68.
    69.    btfsc PORTA, 2                    ;check to see if the E key is pressed
    70.    call noteE                        ;if so start note
    71.
    72.    goto main
    73.
    74.
    75. ;*********************************subs**********************************
    76. noteC
    77.    banksel     OPTION_REG      ; Bank containing register OPTION_REG
    78.    bcf         OPTION_REG,T0CS ; TMR0 counts pulses from oscillator
    79.    bcf         OPTION_REG,PSA  ; Prescaler is assign to timer TMR0
    80.
    81.    bsf         OPTION_REG,PS0  ; Prescaler rate is 1:256
    82.    bsf         OPTION_REG,PS1
    83.    bsf         OPTION_REG,PS2
    84.
    85.    banksel     INTCON          ; Bank containing register INTCON
    86.    bsf         INTCON,5     ; TMR0 interrupt overflow enabled
    87.    bsf         INTCON,GIE      ; Global interrupt enabled
    88.
    89. Loop
    90.
    91.    btfss       INTCON,2
    92.    goto $-1
    93.    bsf           PORTB, 7
    94.
    95.    banksel     OPTION_REG      ; Bank containing register OPTION_REG
    96.    bcf         OPTION_REG,T0CS ; TMR0 counts pulses from oscillator
    97.    bcf         OPTION_REG,PSA  ; Prescaler is assign to timer TMR0
    98.
    99.    bsf         OPTION_REG,PS0  ; Prescaler rate is 1:256
    100.    bsf         OPTION_REG,PS1
    101.    bsf         OPTION_REG,PS2
    102.
    103.    banksel     INTCON          ; Bank containing register INTCON
    104.    bsf         INTCON,5     ; TMR0 interrupt overflow enabled
    105.    bsf         INTCON,GIE      ; Global interrupt enabled
    106.
    107.    btfsc       INTCON,2
    108.    goto $-1
    109.    bcf         PORTB, 7
    110.
    111.    goto Loop
    112.
    113.
    114. noteD
    115.   banksel     OPTION_REG      ; Bank containing register OPTION_REG
    116.    bcf         OPTION_REG,T0CS ; TMR0 counts pulses from oscillator
    117.    bcf         OPTION_REG,PSA  ; Prescaler is assign to timer TMR0
    118.
    119.    bcf         OPTION_REG,PS0  ; Prescaler rate is 1:2
    120.    bcf         OPTION_REG,PS1
    121.    bcf         OPTION_REG,PS2
    122.
    123.    banksel     INTCON          ; Bank containing register INTCON
    124.    bsf         INTCON,5   ; TMR0 interrupt overflow enabled
    125.    bsf         INTCON,GIE      ; Global interrupt enabled
    126.
    127. Loop1
    128.
    129.    btfss       INTCON,2
    130.    goto $-1
    131.    bsf           PORTB, 7
    132.
    133.    banksel     OPTION_REG      ; Bank containing register OPTION_REG
    134.    bcf         OPTION_REG,T0CS ; TMR0 counts pulses from oscillator
    135.    bcf         OPTION_REG,PSA  ; Prescaler is assign to timer TMR0
    136.
    137.    bcf         OPTION_REG,PS0  ; Prescaler rate is 1:2
    138.    bcf         OPTION_REG,PS1
    139.    bcf         OPTION_REG,PS2
    140.
    141.    banksel     INTCON          ; Bank containing register INTCON
    142.    bsf         INTCON,5   ; TMR0 interrupt overflow enabled
    143.    bsf         INTCON,GIE      ; Global interrupt enabled
    144.
    145.    btfsc       INTCON,2
    146.    goto $-1
    147.    bcf         PORTB, 7
    148.
    149.    goto Loop1
    150.
    151.
    152. noteE
    153.    banksel     OPTION_REG      ; Bank containing register OPTION_REG
    154.    bcf         OPTION_REG,T0CS ; TMR0 counts pulses from oscillator
    155.    bcf         OPTION_REG,PSA  ; Prescaler is assign to timer TMR0
    156.
    157.    bsf         OPTION_REG,PS0  ; Prescaler rate is 1:16
    158.    bsf         OPTION_REG,PS1
    159.    bcf         OPTION_REG,PS2
    160.
    161.    banksel     INTCON          ; Bank containing register INTCON
    162.    bsf         INTCON,5   ; TMR0 interrupt overflow enabled
    163.    bsf         INTCON,GIE      ; Global interrupt enabled
    164.
    165. Loop2
    166.
    167.    btfss       INTCON,2
    168.    goto $-1
    169.    bsf           PORTB, 7
    170.
    171.    banksel     OPTION_REG      ; Bank containing register OPTION_REG
    172.    bcf         OPTION_REG,T0CS ; TMR0 counts pulses from oscillator
    173.    bcf         OPTION_REG,PSA  ; Prescaler is assign to timer TMR0
    174.
    175.    bsf         OPTION_REG,PS0  ; Prescaler rate is 1:16
    176.    bsf         OPTION_REG,PS1
    177.    bcf         OPTION_REG,PS2
    178.
    179.    banksel     INTCON          ; Bank containing register INTCON
    180.    bsf         INTCON,5   ; TMR0 interrupt overflow enabled
    181.    bsf         INTCON,GIE      ; Global interrupt enabled
    182.
    183.    btfsc       INTCON,2
    184.    goto $-1
    185.    bcf         PORTB, 7
    186.
    187.    goto Loop2
    188.
    189.    return
    190.
    191.   end                         ; End of program
    192.
