I just tried it: it does nothing when connected to ground, and results in a flat line when connected to the negative in a split supply.You can try putting your Timing resistor on pin 8 and pulling pin 9 to ground (negative power rail). Just in case that works.
I don't understand what you mean here. Are you saying that the circuit works correctly at very high frequencies and not at low frequencies? If so, at what frequencies does the circuit work correctly and incorrectly. Maybe the low frequency timing cap is bad or is a polarized cap installed in the wrong polarity?... unless for very high frequencies, which allows you to increase the voltage to the maximum allowed.
