I'm using a EDE2208 IC to turn a signal from a momentary input into a toggle signal for my circuit. The IC works perfectly, the only problem I ran into was when powering up the circuit, the change in voltage from 0V to 5V activated the IC. I need the ouput signal to be zero until the button is pushed.
Is there anyway I could isolate the start-up signal, so it wont activate the IC? Would there be a way to use a JK Flip Flop to get around this?
Thanks guys
Thanks guys
