I've developed a project that basically consists of reproducing the Arduino Mega schematics and export it to an ECAD tool to test my PCB design skills after a technical course.
After recieving the PCB and soldering the components everything worked fine from an electrical point of wiev. The problem came up in the very last step when I tried to program the PCB from the Arduino IDE using the USB. The IDE tries to upload the sketch but this never happens, giving the following error:
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7 Using Programmer : wiring Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
An error ocurred while uploading the sketch
Until now I've tried (successfully) the following steps:
I've to point out that to program the PCB from outside I had to remove C7 cap (100nF) to cancel ATMEGA16U2 DTR line reset effects on ATMEGA2560-16AU. After programming, I resoldered it to allow ATMEGA16U2 to communicate with ATMEGA2560-16AU (ARDUINO MEGA Schematics attached).
I'll be very grateful if anyone can give me some feedback to fix this issue.
Thanks in advance
- I've programmed ATMEGA2560-16AU using an Arduino USB-to-Serial module, which is basically the same circuit included in the Arduino Mega, and it works fine. Before programming, I bootloaded the micro following information offered in Arduino official web page.
- I've followed a tutorial to flash ATMEGA16U2 using ATMEL's FLIP software. After put the microcontroller in DFU mode and install the proper Arduino driver, the computer and Arduino IDE both recognize it as a COM port, so everything looks to be fine.
Thanks in advance
