I'm having a great deal of trouble getting these two nodes to communicate with each other. They work in loopback mode but not in normal mode. I've included the two most likely problem functions below, as well as a quick schematic, and pictures of the nodes. I'm not sure if it is software or hardware. I have tried many different things, but I can't seem to get them to work.
A zipfile containing the J1939 library I have used once before and had to modify, as well as my current hobbled together code. I used the XC8 compiler with MPLABX and the PICKIT3. The files are located at http://tomt.me/halp/CANTest.zip
Thank you for your time, and any insights you can help me with.
Rich (BB code):
//Send a test message
void testmsg(unsigned char msg){
TXB0EIDH = 0x0000; //Clear extended IDs
TXB0SIDH = msg;
TXB0D0 = 1;
TXB0DLC = 0x00 | 1; //changed from count to 1 //Set the RTR flag to false, and set the DLC register.
TXB0CON = TXB0CON | 0x08 ; //Set the TXREQ flag.
LED3 = 1;
while (TXB0CONbits.TXREQ);
while (!(LED3=0)); //This SHOULDN'T BE REQUIRED!!!
LED1 ^= 1;
Rich (BB code):
* Initilize the chip, and CAN module.
void Init(){
// Set the internal oscillator to 64MHz
OSCCONbits.IRCF = 7;
OSCTUNEbits.PLLEN = 1;
//Initialize I/O to be digital
ANCON0 = ANCON1 = 0x00;
//Set I/O
TRISC = 0x0F; // LED's then Inputs
//Set all LED's off.
LATC = 0x00;
//Set io for tx/rx pins
TRISB3 = 1; //RX pin
TRISB2 = 0; //TX Pin
// Initialize CAN module
// Enter CAN module into config mode
CANCON = 0x80; //REQOP<2:0>=100
while(!(CANSTATbits.OPMODE ==0x04));
//Select ECAN Mode 2
ECANCON = 0xA0; //enhanced fifo, with interrupt when one buffer remains, Acceptance Filters 0, 1, 2 and BRGCON2, 3
// Initialize CAN Timing to 1 Mbps @ 64MHz
//BRGCON1 = 0x81; //0000 0011 //SJW=3TQ BRP 1
//BRGCON2 = 0xB8; //1011 1000 //SEG2PHTS 1 sampled once PS1=8TQ PropagationT 1TQ
//BRGCON3 = 0x05; //0000 0101 //PS2 6TQ
// 100 Kbps @ 64MHz
BRGCON1 = 0x93; //0001 1111 //SJW=3TQ BRP 31
BRGCON2 = 0xB8; //1010 0000 //SEG2PHTS 1 sampled once PS1=8TQ PropagationT 1TQ
BRGCON3 = 0x05; //0000 0010 //PS2 6TQ
// Initialize Receive Masks
//Recieve ALL messages
RXM0EIDH = 0x00; //Extended ID Mask
RXM0EIDL = 0x00;
RXM0SIDH = 0x00; // Standard ID Mask
RXM0SIDL = 0x00;
//Disable Filters
RXFCON0 = 0x00; //Disable all
RXFCON1 = 0x00; //Disable all
// Enter CAN module into normal mode
//CANCON = 0x40; //Loopback Mode
CANCON = 0x00; //Normal Mode
while(CANSTATbits.OPMODE==0x00);
// Set Receive Mode for buffers
RXB0CON = 0x00;
RXB1CON = 0x00;
