problems about the bridge rectifiers 300A 100V
Discussion in 'General Electronics Chat' started by jessietechele, Aug 8, 2013.
  1. jessietechele
    Jul 23, 2013
    5
    As u know, % efficiency of rectifier means how much rectifier is efficient in converting AC to DC.
    i.e suppose rectifier is 90 % efficient
    let's input power to rectifier is 10 KW , rectifier is 90 % efficient then power at output of rectifier is 9 Kw
    could anyone tell me about the efficiency of the model "bridge rectifier300A 100V" and the ripple factor(% of ripples) of it.
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    A bridge rectifier that is 90% efficient?
    You must be using Selenium type!! :rolleyes:
    Max.:)
  3. wayneh
    Sep 9, 2010
    12,379
    3,232
    Ripple is 100% if there is no filter. And the performance of the filter will depend on the load placed on it.
  4. crutschow
    Mar 14, 2008
    13,482
    3,370
    A rectifier doesn't have a fixed percentage efficiency and efficiency is seldom used to describe rectifier operation. The rectifier data sheet will show the forward voltage drop versus current. This can be used to calculate the power loss versus current. The "efficiency" can then be calculated from this if you want but it varies with the output voltage (and hence output power) for a given current.
  5. wayneh
    Sep 9, 2010
    12,379
    3,232
    So true. I bet the OP's rectifier wouldn't look so good with 2V p-p AC.
  6. jessietechele
    Jul 23, 2013
    5
    THKS ur reply!
