Problem
Discussion in 'General Electronics Chat' started by Annu007, Nov 16, 2006.
  1. Annu007
    Jun 12, 2006
    11
    Can anybody show me how to solve this problem (Value of R2)?
  2. kubeek
    Sep 20, 2005
    4,691
    806
    Best solution for me is using Kirchhoff´s law:
    1) Sum of currents in one joint equals 0
    2) Sum of voltages in one loop (don´t know the right term) is equal to zero.
    Look at www.allaboutcircuits.com for explanation
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Once you have reviewed the material contained in the link that Dave has posted, then give the calculation a whirl and then post your calculations and your results. We will be happy to provide you a bit of guidance if needed.
    hgmjr
  5. Annu007
    Jun 12, 2006
    11
    I came up with 13K for R2.
    Vo = 0.25ma * 5K +0.7V
    Vo = 1.95V
    I1= I2 + ID
    I1 = 12V/30K =0.4mA
    ID = 0.25mA (Given)
    I2 = 0.4-0.25 =0.15mA
    V0 = 1.95V
    R2 = 1.95V/0.15mA = 13K
  6. richbrune
    Oct 28, 2005
    106
    The part about 12v/30k doesn't look right; the voltage drop across the 30k can't be all of the 12v, it's got to be something less than that, seems like about 9 or 10 volts, because you've got to subtract the voltage drops caused by all of the 3 remaining components. I got 40678, but I don't have time to check it before I leave---Sorry, Rich
  7. Annu007
    Jun 12, 2006
    11
    Vo = 12-1.95 = 10.05V
    I1 = 10.05/30K = .335mA
    I2 = 0.335-.25 = .85mA
    R2 = 1.95/0.85 = 22.94K
  8. Syed
    Dec 5, 2005
    6
    Right..... except 0.335-0.25=0.085 and 1.95/0.85=2.2941 so 1.95/0.085=22.941
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    Not a bad effort, annu007.
    I used Millman's Theorem and arrived as 22.941K....
    hgmjr
