So some guys at work needed to modify a piece of equipment we are trying to field by adding an external speaker http://www.radioshack.com/product/index.jsp?productId=2104031&tab=features.
Come to find out it only works on a little less than half of the units we have.
The ones that don't work start to chirp and eventually (sometimes very quickly) alarm.
My task is to find a component in the circuit that can be replaced by the same component with different tolerances. I suspected hFE of Q3, so I tested four transistors from working units and four from the bad ones but they were all similar.
Should I have my solder shop remove Q4 so I can test them?
Is there a simple Filter solution I can stick in the base of the speaker without modifying the equipment any further (to much bureaucracy and time for that)?
Hopefully the schematic is descriptive enough to help you help me if not ask and I'll elaborate
(The red is the mod)
p.s.the speaker itself is modifiable easy enough, its the further modifying of the equipment that my boss wants to avoid.
p.p.s. If its uncool to ask about work stuff I'm sorry
thanks for your time
joe
joe
