problem with Xilinx ise 9.1 simulator
Discussion in 'General Electronics Chat' started by nabilos23, Jul 17, 2009.
  1. nabilos23
    Jul 17, 2009
    hello all
    iam using Xilinx ISE 9.1 to implement a Verilog program in my FPGA spartan3, BUT my problem is the following:
    When i check syntax i have so many erros, all erros are that Xilinx ISE 9.1 does not recognize any logic gates of my Verilog NETLIST, the error is -> Could not find module/primitive 'NOR3' or NAND2, INV0 etc......
    do you think it's a problem of lack library?
    My Verilog NETlist is:
    module logique_de_controle_dicho ( Clk, Rst, niv_compar, calib_start, calib_ok,
    DATA, test_si1, test_so1, test_si2, test_si3, test_se);
    output [7:0] DATA;
    input Clk, Rst, niv_compar, calib_start, test_si1, test_si2, test_si3,
    test_se;
    output calib_ok, test_so1;
    wire n_0, n_2, n_3, n_4, n_5, n_6, n_7, n_8, n_9, n_10, n_11, n_12, n_13,
    n_14, n_15, n_16, n_17, n_18, n_19, n_20, n_21, n_22, n_23, n_24,
    n_25, n_26, n_27, n_28, n_29, n_30, n_31, n_32, n_33, n_34, n_35,
    n_36, n_37, n_38, n_39, n_41, n_42, n_43, n_44, n_45, n_46, n_47,
    n_48, n_49, n_50, n_51, n_52, n_53, n_54, n_55, n_56, n_57, n_58,
    n_59, n_60, n_61, n_62, n_63, n_64, n_65, n_66, n_67, n_68, n_69,
    n_70, n_71, n_72, n_73, n_74, n_75, n_76, n_77, n_78, n_79, n_80,
    n_81, n_82, n_86, n_87, n_88, n_89, n_90, n_91, n3, n6, n7, n8, n9;
    OAI220 g2812 ( .A(n_59), .B(n_0), .C(n_81), .D(n_70), .Q(n_82) );
    INV0 g2822 ( (n_75), (n_81) );
    INV0 g2819 ( .A(n_77), .Q(n_80) );
    OAI220 g2827 ( .A(n_78), .B(n_88), .C(n_52), .D(n_26), .Q(n_79) );
    AOI220 g2820 ( .A(n_49), .B(calib_start), .C(n_54), .D(n_37), .Q(n_77) );
    INV0 g2828 ( .A(n_69), .Q(n_76) );
    OAI210 g2823 ( .A(n_67), .B(n_65), .C(n_57), .Q(n_75) );
    OAI210 g2825 ( .A(n_91), .B(n_78), .C(n_66), .Q(n_74) );
    AOI210 g2824 ( .A(n_48), .B(n_71), .C(n_86), .Q(n_73) );
    OAI220 g2826 ( .A(n_71), .B(n_37), .C(n_47), .D(n_70), .Q(n_72) );
    AOI220 g2829 ( .A(n_68), .B(n_67), .C(n_51), .D(DATA[7]), .Q(n_69) );
    OAI210 g2838 ( .A(n_25), .B(n_11), .C(n_68), .Q(n_66) );
    NOR30 g2845 ( .A(n_56), .B(n_62), .C(DATA[0]), .Q(n_65) );
    OAI310 g2846 ( .A(n_27), .B(n_70), .C(n_33), .D(n_43), .Q(n_64) );
    end module
    if someone can help I will be recognizing
    thank you
    Nabilos
