Problem with VME-Bus
Holzwurm56
Joined May 20, 2010
I am a hobbyelectronic and get some cnc controllercards , but unfortunelly with a 16 bit VME-Bus . Does someone knows a way to use the cards on a PC ? Does some build an adapter ISA , PCI , USB , RS232 , Parallel to VMVE-Bus , or knows where I can get so one ?
Many thanks for every answer
Hans
beenthere
Joined Apr 20, 2004
15,819
I would bet you would need to make some intermediate device to do the interfacing. It might have to look like a VME controller to the cards, and perphaps talk to the PC through USB.
Here is the VME interface spec - http://www.interfacebus.com/Design_Connector_VME.html
That would be the guide to constructing an adapter. It would require a microcontroller to do the operation.
The device at the link is not an endorsement, but an example of what you find using "vme to usb interface" - http://embedded-computing.com/vm-usb
