problem with VB6 code
Discussion in 'Programmer's Corner' started by ravinaval, Apr 14, 2012.
  1. ravinaval
    Apr 14, 2012
    7
    - I m using P89V51RD2
    I want to read data from PORT-2 of microcontroller using VB-6 software
    while reading data form port, VB-6 shows the ASII value of the data but I want the decimal value
    PLEAZ HELP
  2. ravinaval
    Apr 14, 2012
    7
    please help me in wrting code in VB-6.0 for reading the data from port of P89V51RD2 and displaying the exact decimal equivalent of data at the port.
    storing it into the data and den displaying it in VB6.0
    PLZ HELP
  3. MrChips
    Oct 2, 2009
    12,625
    3,451
    Use the ASC function.
  4. ravinaval
    Apr 14, 2012
    7
    ASC function is not working in our case
    this is my code , plz suggest me or give me modified code
    Public i As Integer
    Dim values() As Integer
    Public Temp_In As Variant
    Public Data_In As Variant
    Dim k As Variant
    Public j As Integer
    Private Sub Form_Load()
    MSComm1.PortOpen = True
    End Sub
    Private Sub MSComm1_OnComm()
    Temp_In = MSComm1.Input
    Text1.Text = Text1.Text & Temp_In
    Data_In = Asc(Temp_In)
    Text2.Text = Text2.Text & Data_In
    End Sub
  5. ravinaval
    Apr 14, 2012
    7
    plz rely coderzzzzzzzzzzzz
  6. DumboFixer
    Feb 10, 2009
    219
    34
    What numbers are you getting and what are you expecting ?
  7. ravinaval
    Apr 14, 2012
    7
    I am giving data = 0011 1001=(39)"hexadecimal" at port -2 of of microcontroller
    but Im getting ascii value of 39HEX ie 9 at the hyperterminal and as well as VB-6 gui textbox.
    I want the same number 39 in my GUI.
    thanku
  8. MrChips
    Oct 2, 2009
    12,625
    3,451
    0011 1001 is not 39- decimal
    It is 57-decimal = ASCII "9"
    There are 10 types of people in the world, those who understand binary and those who don't.
  9. ravinaval
    Apr 14, 2012
    7
    sorry
    I mean I want to display 57 which is decimal equivalent of data at port 2 of my uc
  10. MrChips
    Oct 2, 2009
    12,625
    3,451
    Write a routine on the MCU equivalent to num2str(int d).
    It is not difficult.
  11. ravinaval
    Apr 14, 2012
    7
    I hav written my code above pls tell me where shud i make change
  12. MrChips
    Oct 2, 2009
    12,625
    3,451
    Can't see the code.
  13. panic mode
    Oct 10, 2011
    1,328
    305
    MrChips, i'm surprised... ;)
  14. MrChips
    Oct 2, 2009
    12,625
    3,451
    Surprised with?
  15. panic mode
    Oct 10, 2011
    1,328
    305
    involvement
  16. MrChips
    Oct 2, 2009
    12,625
    3,451
    I steer people in the right direction but I don't follow them.
  17. DumboFixer
    Feb 10, 2009
    219
    34
    Why not use the str function ?
    This will convert a number into a string so 59 will become "59".
    The application help will tell you how to use the str function.
