I didn't know how to set that configuration. See the attached picture.
It's always good when a project finally works. Congratulations.I solved the problem after looking in the PIC's datasheet, and setting the config bits right. The circuit is working 100% now. Thanks again and again.
I've kinda seen it. In my work I tend to use insulated fly wires for the signal connections, and thicker solid bus wire for power & ground. The bus wire is uninsulated, so I solder it down to keep it in place. I just don't hit each and every donut, every 5 or so is fine.I have never seen perfboard used that way. The results look good, but it's a lot of soldering. Generally, I use fly wires on the bottom of the board.
by Duane Benson
by Duane Benson
by Jake Hertz
