problem with TINA-TI using square voltage sources
Discussion in 'Electronics Resources' started by joseda, May 4, 2009.
  1. joseda
    May 4, 2009
    6
    Hi all!!
    I've trying to simulate a simple circuit to get the commutation time of a transistor (2N2222) with a voltage generator in the form of a square signal in the base of the transistor.
    The source is one with a frecuency of 500kHz (a period of 2us)
    But this program can't simulate that!! Always i get the message "Convergence problem. Check the analysis problem"
    I've attached a pdf explaining this clearly
    Any clue about that?
    Thanks in advance
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Works OK for me in TINA
  3. joseda
    May 4, 2009
    6
    Are you using the complimentary version TINA-TI or the full version TINA?
    Thanks!!
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    The complimentary version.
  5. joseda
    May 4, 2009
    6
    Could you post or send me the schematic (the *.TSC file) compressed in a zip or rar file?
    Thanks in advance!!
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Hope this works.
  7. joseda
    May 4, 2009
    6
    whoaa!!
    Thanks, TINA-TI astounds me!!
    You must use an IC but if you use the first IC inside the tab of SpiceMacros/Operational Amplifiers it doesn't work!!!
    And if you use the first IC inside the tab of Semiconductors/Operational Amplifiers it works!!!
    What a strange behaviour for a program!!!
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    I see - that's tricky!
    I don't use TINA often enough to unearth such issues. I've got used to Simetrix.
    Anyway - I'm glad it works for you now.
  9. CDRIVE
    Jul 1, 2008
    2,223
    99
    The TI version of Tina requires a TI component to be loaded into the schematic editor. Make a template using a TI component and short all the pins. Drag it off to the right side of the screen so it not visible. Save the schematic as Template or whatever name you like. Now you can open the Template, instead of New, when you start a new schematic.
    This is what I did before I purchased Tina Classic.
