I am building a model railway using digital control and would like to add some ‘keep alive’ capacitors to a locomotive. An age old problem with these railways is that the trains will tend to hesitate or stop if they encounter dirty track and the power is momentarily cut off.
However each locomotive contains a digital decoder chip and if you add a large capacitor to the power input of the chip it will provide enough discharge power to help the loco over dead spots on the track. This is a tried and tested method and works well.
So I added 3 capacitors in parallel to a locomotive. These were all 4700uf 16v. The circuit also had a 150ohm resistor on the +ve lead to limit the charge rate of the capacitors, and a diode across the resistor to enable the current to bypass the resistor when discharging.
The works fine, if you lift a running loco from the track it keeps going without power for about a second.
My problem…
The caps are large and difficult to fit in smaller locos, so I thought I would switch to super capacitors instead, the type usually used for memory backup. However using the same circuit as above nothing happens, they do not work.
I have connected 4 backup capacitors in series, each is 0.33F and 5.5v. So connected in series they should give me a whopping 83250uf and 22v. They are also much smaller than electrolytic caps.
I have checked with a multi meter and they are charging up, and they slowly drain when you remove the train from the track, but the loco does not run.
Is there perhaps a difference between standard electrolytic and backup capacitors that I not accounting for?
My problem…
