Hi dear members, I have bought an OW5691 which is a 6V dc relay as shown in the below link:
http://html.alldatasheet.com/html-pdf/105895/ETC/OW5691/53/1/OW5691.html
System:
http://www.reuk.co.uk/Simple-Sump-Pump-Controller.htm
The main problem is that the datasheet is in french and this is a big problem for me. I have been having problems as I am building the below system which is a simple sump pump controller, which is controlled by two float switches giving 5V dc. Now I have managed to simulate this on proteus and it worked perfectly, but when in practice as always something is wrong. I built the circuit more than once and the relay doesn't seem to latch. It is supposed to latch when both switches are closed, until the last switch in the bottom of the tank is opened and it unlatches and stops the pump. Can someone give me ideas on why this relay doesn't seem to latch when the top switch is opened? Thanks in advance,
Regards,
FiatUno
System:
Regards,
FiatUno
