problem with some gate
Discussion in 'Homework Help' started by roeyhaim, Nov 22, 2010.
  1. roeyhaim
    Nov 22, 2010
    6
    hello guys.
    I'm stuck with a problem and need help...
    This is the Q:
    I tried for all night and didn't get it....
    any suggestion?
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Where are you stuck?
    A\smile B= A\overline{B}
    Apply that to the function, have you had previous examples of applying logic to a function?
  3. roeyhaim
    Nov 22, 2010
    6
    well i tried to simplify the function.
    I got F(x,y,z) = xy + xz'
    but i dont know how to continue...
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    You did well simplifying the function. Your task from now on is to convert any single operation to a smile operation. Start with a factorization.
    Here are some hints:
    a+b'=(a'b)'
    x'=(x'1)
    Can you figure it out?
  6. renotenz
    Oct 25, 2010
    11
    You can still simplify that function actually... there's one common letter there
    After that you shall see a pattern which Georacer already wrote.
    Also remember that : A'B = BA'
    Cheers :) <= Smile function for you :D
  7. roeyhaim
    Nov 22, 2010
    6
    I'm sorry, but i still don't get it...
    I give up...
    My brain is gonna explode.
    Thanks for trying :)
    Now I scared from the yellow smile :D
  8. Georacer
    Nov 25, 2009
    5,151
    1,266
    Don't give up yet. Try a bit more. You have problems doing the factorization? Finding the part to be substituted?
    Post any scribbles you have done, even if they are completely wrong. Don't let a good thread end without a closure.
  9. roeyhaim
    Nov 22, 2010
    6
    OK...
    but please dont laugh at me...
    i thought maybe to put the x out and then to play a little with the y
    maybe to do some demorgan.
    but the Q is what to do with the +
    any hint / advise?
  10. renotenz
    Oct 25, 2010
    11
    There it is.
    Put X out, then you'll get X(Y + Z')
    See any resembelance with what Georacer has typed?
    Don't forget that your :) is A'B, same as BA', same as X'Y, YX', etc...
  11. roeyhaim
    Nov 22, 2010
    6
    so, tell me if im right
    now i got X(y'z)'
    and put this in circuit :
    X:)1 = X'
    Y:)Z = Y'Z
    Y'Z:)1 = (Y'Z)'
    X':)Y'Z = X''(Y'Z)'
    X''(Y'Z)' = X(Y+Z')
    Am I right?
    This is the solution?
  12. Georacer
    Nov 25, 2009
    5,151
    1,266
    Not quite.
    Y'Z:)1 = (Y'Z)' is correct only with parentheses: (Y'Z):)1 = (Y'Z)' and
    X':)Y'Z = X''(Y'Z)' is wrong.
    You have also written down some unneded equations. So let's sum it up:
    xy+xz'=
    x(y+z')=
    x(y'z)'=
    (y'z)'x=
    Can you take it from here and substitute for the :) operation? Make one step at a time and start from inside out.
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    From the original question, the solution should have the :) operator only, so go through the steps to substitute it, and leave it (and ONLY the :)) in for the final solution.
  14. roeyhaim
    Nov 22, 2010
    6
    sorry but im lust again...
    I feel so :eek:
    What i need is to figure out how to get
    X(Y'Z)' by input to a :) gate only two variables?
    with no other gates?
    just ONE AND ONLY :) gate?
  15. thatoneguy
    Feb 19, 2009
    6,357
    718
    As I read it, you can use all the :) gates you want, but you aren't allowed to have an inverter.
