Problem with SCR's driven by 4017b
Nickage
Joined Jan 3, 2013
7
All,
I am building a sequencer control board, using a 4017b decade counter. I built the circuits in steps to verify progress. The problem is, once I setup the 2n5060 SCRs to latch whe nthe outputs are triggered, the test LEDs chase as if the SCRs are not there.
The 4017b outputs are directly wired to the gate, 13.8VDC going to the anode, and the cathode is wired to the LED/resistor array. Am I missing something? The voltage at the gate when the output is on is 13.6VDC.
Any help would be appreciated!
tubeguy
Joined Nov 3, 2012
1,157
Look at this - circuit with motor and battery
http://www.allaboutcircuits.com/vol_3/chpt_7/5.html
The Led's need to be between V+ and the anode, cathode to ground.
Be aware that once the scr's are triggered they latch on and must have the DC voltage removed before they shut off.
What do you want this circuit to do ??
Transistors would be better if you just want to flash the led's
Look at the datasheet for the 4017. You should connect pin 13 either to gnd or V+... But which ???
Nickage
Joined Jan 3, 2013
7
I made the switch you suggested, and it works. What I'm trying to do is get a row of LEDs to light up like chaser lights, only I want them to stay on.
Sensacell
Joined Jun 19, 2012
3,451
Also note that SCR's are current controlled devices, not voltage controlled devices. You need a current limiting resistor in series with the gate lead.
The cathode should be tied to GND. with the load connected to the anode, it's then a "sinking driver"
Then, of course, the SCR's will NEVER turn off again unless you interrupt the current flow by an external means. Using full-wave rectified AC as the power source will allow the SCR to turn off every 1/120th of a second, when the voltage crosses zero.
vrainom
Joined Sep 8, 2011
126
There is a way to turn off scrs after they're latched on, and that's forcing the gate to a voltage equal or lower than the cathode's so the current is cut off. That's why your scrs were turning off when the output that drives the gate changed states. I think that in order to make your previous configuration latch you could have used a diode and a limiting resistor in series between the 4017 ic and the gate. Or maybe just the limiting resistor if it's large enough so it won't be able to cut the gate's current.
tubeguy
Joined Nov 3, 2012
1,157
You could connect a PNP transistor between V+ and the LED's supply, connected to the reset thru a 10k resistor to base. Emitter to V+, collector to the LED's anodes.
When reset is low the transistor is on supplying voltage to LED's.
Reset going high will turn off LED and SCR voltage. Should reset the SCR's (maybe not the last --try it.)
You might put a 2.2k resistor from base to emiiter also.
Current limiting resistors in series with SCR gates could be 4.7k-10k.
And might need a 47k resistor from SCR gate to Gnd,
Dodgydave
Joined Jun 22, 2012
11,304
It's a rudimentary sketch, but should give you an idea of what's going on.
Connect the load in the Anode side like this...
BUT the thyristor will latch on when it is triggered and can only be switched off when the Anode current is broken, or the Anode and Cathode are shorted out, so if you want to use it as a chaser, you need to use transistors.
