PROBLEM WITH SCHMITT TRIGGER (HYSTERESIS CURRENT CONTROL)
Discussion in 'The Projects Forum' started by enricuzzo, Jan 31, 2016.
  1. enricuzzo
    Jan 31, 2016
    INVERTERR.png Hello everyone, I'm trying to simulate with Orcad Pspice a Three phase inverter with hysteresis current control.
    I attached my circuit.
    I did it with 3 non-inverting Schmitt trigger, setting ratio R2/R1 =30 so that, as the ideal opamp has +-15V output, I should have the hysteresis band width=1. The E generators have a gain=-1 so that they work as a Not port. The H generators have a gain=1 so I have voltage feedback. I put two vsin with offset, on the bottom, to see the band margins.
    Well, currents through the loads should follow the vsin reference (setted on 50hz, ampl=6) with a ripple depending on the band widht, but It doesn't work: current through L1 is a sine curve among 0A, the one throug L2 is among 20A, and through L3 among -20A.
    Can somebody help me?
    Thanks.
  2. crutschow
    Mar 14, 2008
    13,529
    3,393
    Sorry, but I really don't understand your problem. :confused:
    What is a "hysteresis bandwidth"?
    What are "E generators" and "H generators"?
    And this makes no sense: "L1 is a sine curve among 0A, the one throug L2 is among 20A, and through L3 among -20A."
    Perhaps you could find someone to help with your English.
  3. enricuzzo
    Jan 31, 2016
    Well, sorry.
    1) Hysteresis bandwidth : I mean the distance between the lower and upper threshold.
    2) E and H generators: voltage generators respectively voltage and current-controlled. In pspice they are E and H blocks.
    3) L1 is a sine curve among 0A: i(L1) is a sinusoidal current with the average value in zero (a typical sine curve). i(L2) is the same with an offset of 20A, and i(L3) with an offset of -20A. And I don't know why.
    Sorry for bad English.
