Problem with rewriting 12f675
Discussion in 'Embedded Systems and Microcontrollers' started by vane, Dec 5, 2009.
  1. vane
    Thread Starter Active Member
    Feb 28, 2007
    181
    My Dad got me some PIC 12f675s and they came today. Uploaded a .HEX to one, it did work, then i put it back on the writer and went to write another version to it, now it says an error saying there is either not a PIC on the programmer board, it isn't in program mode or PIC type os mismatched with software, i am wondering whether there is a problem with erasing.
    I tried another PIC and it only wrote to it once, then it gives the error, to my knowledge they are not single use PICs, i certainly didn't mean to get single use PICs.
    I have the velleman K8048 programmer board if that helps.
  2. Markd77
    Sep 7, 2009
    2,803
    594
    Have a look at thread "Fighting a 12F675..." which is about 20 posts down and see if that answers your questions.
  3. vane
    Feb 28, 2007
    181
    Well thats just bloomin great :( the programmer i get turns out to have a quite serious bug, do you know if this works?
    Buying a new programmer will be a 100% no no due to lack of funds :(
  4. vane
    Feb 28, 2007
    181
    This has never ever happened on any of my other chips :s
  5. vane
    Feb 28, 2007
    181
    Tried shorting out D7 to no avail :s
  6. vane
    Feb 28, 2007
    181
    99% sure it aint the code protection, it doesn't code protect my 16f84A when that is written to
    Is there a configuration in picprog2 for disabling the code protection?
  7. vane
    Feb 28, 2007
    181
    What makes you sure it is the write protection?
  8. vane
    Feb 28, 2007
    181
    From what i have heard i need to supply 13.5 volts to MCLR then put power to VDD to get it into programming mode :s Can anyone speculate on anything i have said?
  9. vane
    Feb 28, 2007
    181
    OK, i have tried doing the manual 13.5 volts to MCLR then erasing the data, now i just get errors like:
    wrote: 2804
    Read: 2004
  10. n9352527
    Oct 14, 2005
    1,198
    I've seen this problem in many different programmers, not only Velleman. There was a guy in this thread experiencing the same problem. He was using a JDM clone. There were also reports of the same problem with Mchp ICD2 programmers. I noticed this problem first when I was working with a MatrixMultimedia dev board.
    Maybe you could try the solution that I used, see in the above thread.
