I have a circuit diagram cotaining an IC (LM358) diagram is divided into two parts each part contain decription of the connection of 5 limbs of the IC (with 8 Limbs) one limb is being repeated twice and the IC is labelled 1/2 LM358 in each diagram, my question is that each one of the two diagrams is a miror of the other with one labelled left and one labelled right does this mean that each of the two diagrams is separate from the other totally and that I should use the components in the circuit twice (resistors and capacitators) or that I can simply connect the IC limbs to common components and use them only once
