Hello
I've written a C program using MicroC for PIC MCU P18F452. It is a simple blinker that will turn on and turn off LEDs on PORTC.F4 , PORTC.F5 and PORTC.F6 in a specified pattern. Pattern will change after 1 second and we have 4 patterns. Here is the program :
void main()
TRISC = 0 ;
PORTC = 0b00010000 ;
Delay_ms( 1000 ) ;
while( 1 )
PORTC = 0b01110000 ;
Delay_ms( 1000 ) ;
PORTC = 0b01010000 ;
Delay_ms( 1000 ) ;
PORTC = 0b01100000 ;
Delay_ms( 1000 ) ;
PORTC = 0b00100000 ;
Delay_ms( 1000 ) ;
The problem is , when I program the MCU , in the reality; on the board , only first 2 patterns will be shown on LEDs and suddenly everything starts from first. I mean :
LED( PORTC.F4 ) is On , LED( PORTC.F5 ) is Off , LED( PORTC.F6 ) is Off
Sleeps for 1 second ...
LED( PORTC.F4 ) is On , LED( PORTC.F5 ) is On , LED( PORTC.F6 ) is On
LED( PORTC.F4 ) is On , LED( PORTC.F5 ) is Off , LED( PORTC.F6 ) is On
No wait ... everything is reset and it seems the main function is called again ...
LED( PORTC.F4 ) is On , LED( PORTC.F5 ) is Off , LED( PORTC.F6 ) is Off -------> Same as the start of main function
And this will be continued ...
Is there anyway to produce such patterns ?! Is it a hardware limitation that we can not write such programs ?! why the MCU goes from first ?! I've written the program using MPLAB but the same occurs with a little change that only the first command in the loop is occured and next everything is reset ...
Please help ??!
void main()
TRISC = 0 ;
Delay_ms( 1000 ) ;
while( 1 )
Delay_ms( 1000 ) ;
Delay_ms( 1000 ) ;
Delay_ms( 1000 ) ;
Delay_ms( 1000 ) ;
Please help ??!
