Problem with PIC16F88 - Analog Input is HIGH?!
Discussion in 'Embedded Systems and Microcontrollers' started by Erbser, Apr 28, 2011.
  1. Erbser
    Apr 28, 2011
    Hey all
    Having a problem with a PIC project hope that you guys here can help me..
    In school I´m making a temprature controllor and I have the problem that one of my two analog inputs doesn´t work!
    the tempratures is coming from two LM35 sending out 10mV/C and one of them is giving me an input to my PIC on approx. 0.25 V the other one is where the problem is, the LM35 is working but the PIN on the PIC is having an output on approx 4.1 V - IT`S AN INPUT PIN!?!?!?!
    I know my problem is in my programming (programming C for the first time) so please help me out here.
    My Code:
    #include <16f88.h>
    #FUSES NOWDT // Slå watchdog timer fra.
    #FUSES INTRC_IO // Ingen clock out.
    #FUSES NOPUT // Ingen power up timer.
    #FUSES NOPROTECT // Ingen read protection.
    #FUSES NOBROWNOUT // Ingen brownout reset.
    #FUSES NOMCLR // Master clear bruges som input/output.
    #FUSES NOLVP // B3 skal bruges som input/output.
    #FUSES NOCPD // Ingen EE protection.
    #use delay(clock=4000000) // Chippen er 4MHz.
    //globale variabler.
    int input1 = 0;
    int input2 = 0;
    int temp_10 = 0;
    int temp = 0;
    void display(int tal, int display)
    //Defines the two LM35 signal pins
    bit_clear(tal, 4);
    bit_clear(tal, 5);
    if (display == 0)
    bit_set(tal, 5);
    else
    bit_set(tal, 4);
    output_b(tal);
    delay_ms(5);
    // Her starter the program
    void main()
    set_tris_a(0b10001111);
    set_tris_b(0b00000000);
    //Analog - Digital konverter
    setup_adc_ports(sAN0);
    setup_adc(ADC_CLOCK_INTERNAL);
    setup_adc_ports(sAN1);
    while(1){
    //Læs temperaturene
    set_adc_channel(0);
    input1 = read_adc();
    set_adc_channel(1);
    input2 = read_adc();
    //Konverts Input til temp
    input1=input1*2;
    input2=input2*2;
    if (input(PIN_A2))
    temp_10 = input1/10;
    temp = input1-(temp_10*10);
    display(temp_10, 0);
    display(temp, 1);
    if (input(PIN_A3))
    temp_10 = input2/10;
    temp = input2-(temp_10*10);
    display(temp, 1);
    THX for helping me out here gys... It needs to me fast! - have deadline tomorrow!
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Can you post your schematic also
  3. russpatterson
    Member
    Feb 1, 2010
    351
    16
    Yes, post the schematic and also which analog pin is working and which one is giving you problems? Double check the datasheet (wouldn't hurt to post a link to that) so you're sure those pins have the analog functionality you want.
    Where are all your functions defined, like set_tris_a() ?
