Problem with Phase sensitive detector example
Discussion in 'Homework Help' started by hunterage2000, Jan 31, 2012.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    I have set-up the attached circuit in multisim from an example ina book and I'm not getting a rectified wave at the output like I should.
    Can anyone tell me whats wrong with it?
  2. hunterage2000
    May 2, 2010
    402
    Can anyone offer any advise?
  3. t06afre
    May 11, 2009
    5,939
    1,222
    What was wrong using the AD630?
  4. hunterage2000
    May 2, 2010
    402
    I thought I'd try to use the method out of the book. But it won't work. I seem to find theoretical info alot but I struggle to put it into practise. Can you see where I am going wrong?
  5. t06afre
    May 11, 2009
    5,939
    1,222
    I have a hunch that you instead of trying to understand the principals. You just use google and then try to copy anything that you hope will work. That approach will never bring you far then it comes to engineering. If you aim at nothing you will hit nothing.
  6. hunterage2000
    May 2, 2010
    402
    I understand the principles in block form but I just dont know how to implement them in practise with an actual circuit.
