Recently I have some problem with simulation in LTspice for operational amplifier (inverting amplifier) circuit. The source voltage and first resistance before opamp is 9 V and 3.6m ohm. The second resistance is 1k ohm. So, the expected output voltage should be
Vout = 9 / 3.6m* 1000 = 2.50 V
But instead, it shows the value of 1.21 V after running the simulation.
I have attached my LTspice drawing here. Kindly appreciate any help and suggestion to me. Thanks in advance!
