problem with Negative supply for ADC
omarcillo
Joined Mar 2, 2009
Hi:
I have a problem using the output of a TC7660 as floating ground fro a voltage reference, so the output of the TC7660 (-2.5V) is the ground for the LT1021 (5 V) reference, I think I need a resistor between this 2 elements but I do no know how to connect that..
Any suggestion is appreciated..
bertus
Joined Apr 5, 2008
22,270
What is the voltage of V+ in your drawing ?
What is the reference voltage you expect on the output of the LT1021 ?
(When the ground pin is at - 2.5 Volts, the reference output pin will be + 2.5 Volt).
Greetings,
Bertus
omarcillo
Joined Mar 2, 2009
V+ is 2.5V that comes from a regulator, and the idea is that output of the LT1021 is +2.5 measured from GND or 5V measured form -2.5V
The output of the LT1021 is very stable 5V, that is why I am using that......
regards
bertus
Joined Apr 5, 2008
22,270
If the - 2.5 Volts is not stable the + 2.5 volts from the LT1021 is also not stable as it is references to the - 2.5 Volts of the ICL7660.
Greetings,
Bertus
omarcillo
Joined Mar 2, 2009
Yeah the 2.5 will no be stable measured from GND but it will be the difference between -2.5 and 2.5, but the reference for my ADC is the difference between the -2.5V and 2.5V....
Regards
bertus
Joined Apr 5, 2008
22,270
What is your problem then ?
I see you have used 1 μF caps at the ICL7660.
In the datasheet they always use 10 μF caps.
Perhaps this makes it a little bit more stable.
Greetings,
Bertus
