Problem with MICROSD Adapter
Discussion in 'Embedded Systems and Microcontrollers' started by shom_show, Apr 27, 2012.
  1. shom_show
    Sep 4, 2010
    15
    Myself Sumanta Kumar Show is facing a problem regarding accessing a
    Memory card within MICROSD Adapter in a MICROSD Atmega Data-Logger.
    Please find the circuit in the Attachment where it is used. I have made all the
    connections according to the circuit diagram. Can anyone please sort out the
    problem?
    Sumanta
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Since you call for a "microSD module connector" we have no idea exactly what that is nor how is should be connected.
    More importantly, all SD card families run off 3.3V so don't turn that on least you burn out your card (though the "module" may correct for this).
  3. shom_show
    Sep 4, 2010
    15
    Actually MICROSD module connector is the base for connecting the MICROSD
    Adapter. I have made the connections according as the circuit given in the
    attachment. But the hyperlink is not able to detect the memory card. So can
    you please help me in detecting the problem.
    Sumanta
  4. shom_show
    Sep 4, 2010
    15
    Are there any driver file required to be installed so that ATMEGA32
    microcontroller is able to detect the memory card through the RS 232 port
    interface. Please have your suggestion regarding solving the problem.
    Sumanta
