Problem with load cell calculation
Discussion in 'The Projects Forum' started by ed-dub, Mar 13, 2016.
  1. ed-dub
    Mar 13, 2016
    5
    Hi all,
    I've spent many hours reading posts across the forums on this site and I have learned a great deal but I find myself stuck trying to understand the load cell calculation I have inherited. I am in the process of rewriting software that obtains reading from a load cell via a micro-controller in real-time and displays the result in a graph. While I could just take was in the code and move it to the rewrite, I was hoping to understand why it is written the way it is.
    What I have so far ...
    The load cell specifications I found here: http://discountloadcells.com/doc/spec_sheets/s_type/hbm_rsc.pdf. Note that mine has a 500lb rating rather than kg.
    The calculation in code is:
    LC Factor = ((LC Rating) /( LC Calibration * LC Sensitivity * Excitation V)) * Zero Offset
    Scale Reading = (LC Rating * V measured) / LC Factor
    where:
    LC Rating = 500lbs (from load cell markings/spec sheet)
    LC Calibration = 2 <-- don't understand where this came from
    LC Sensitivity = 2 (specsheet mV /V)
    Excitation V = 5 (from micocontroller, spec sheet, and digi-meter)
    Zero Offset = .004882 V (looks to be the measure voltage for the load cell unloaded. it's roughly what the digi-meter shows at least)
    Given the above, the load cell factor is 0.12207. At a voltage reading of 0.015, the code outputs 61.44 lbs.
    Given everything I have read, the calculation does not seem correct. I especially do not understand where the Load Cell calibration value originates and why there is a load cell factor involved. Everything that I have read seems to indicate that the calculation to derive lbs should be as simple as (LC Rating * V measured)/ (LC Sensitivity * Excitation V) and the offset subtracted (i.e. Y = MX + B). Could someone help me:
    1) Understand why this calculation is written the way it is (i.e. Load Cell factor)
    2) Where the LC Calibration is coming from and what it represents
    Again I could take it at face value and move on but it's driving nuts trying understand and I just can't let it go.
    Thanks in advance.
    -Ed
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    cmartinez likes this.
  3. ed-dub
    Mar 13, 2016
    5
    Max,
    Thanks for taking the time to reply and doing it so quickly. After skimming through the link you provided, I have to ask, did you post the right one? I'm not finding a reference to the MCP3421 and/or code.
    -Ed
  4. ed-dub
    Mar 13, 2016
    5
    @MaxHeadRoom was this the correct link? I didn't find the content you referenced.
    To the rest of the board... any thoughts?
  5. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Something here.
    Max.
  6. ed-dub
    Mar 13, 2016
    5
    @MaxHeadRoom thanks again for the reply and sharing the code. I am really only looking to understand the calculation I shared. In working my way through the sample application in the attachment, I am still unable to find a clear explanation of the formula or even if it is correct. I'll guess I will have to take it at face value unless you or someone else has the time to clarify.
    -Ed
  7. WBahn
    Mar 31, 2012
    18,085
    4,917
    One way to see that the formula for LC Factor (where did IT come from? I didn't see it in the data sheet) is highly suspect is to ask what the LC Factor would have been had the load zero output been 0 V when unloaded.
  8. ed-dub
    Mar 13, 2016
    5
    I would tend to agree based on reading. However, the zero offset in the factor is a hard coded constant in the code. I have no idea where the calibration value us coming from but at least it an input setting with a default value of 2. I hesitant to just rewrite the formula without a good understanding. A different formula will likely have different scale readings and that I will need to explain.
    -Ed
